BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      10-11-2024, 11:51 AM   #1
RobM2
Drives: 2024 BMW M2
2024 BMW M2  [10.00]
2025 BMW X3 M50  [10.00]
M4 CSL Strut Brace
Anyone install this on their G87?
https://ind-distribution.com/product...sl-strut-brace
https://www.getbmwparts.com/oem-part...ce-51617885847
      10-11-2024, 12:08 PM   #2
rons e92
60-130 Enthusiast
rons e92's Avatar
Had it on my last G87. Will install it on the one I have in production right now.
If you order from IND, they provide the two extra bolts you need.
If you order from GetBmwParts, you'll need to order two bolts, part number is 7119907857.
RobM2265.50
      10-11-2024, 12:32 PM   #3
fanofbmwe46
Any noticeable change in driving dynamics or is it mainly for aesthetics with hood open?
      10-11-2024, 12:38 PM   #4
RobM2
Drives: 2024 BMW M2
2024 BMW M2  [10.00]
Thank you so much for the heads up on the bolts.
I was thinking of ordering from IND as GetBmwParts says they need to ship it first from Germany and presumably/hopefully IND as some in stock.
rons e921911.50
      10-11-2024, 12:39 PM   #5
RobM2
Drives: 2024 BMW M2
2024 BMW M2  [10.00]
I'm not going to pretend it'll be super noticeable on the street, but it is significantly heftier and adds two more connection points and in general the CSL upgrades aren't gimmicks.
Gbrown34.50
      10-11-2024, 01:07 PM   #6
RobM2
Drives: 2024 BMW M2
2024 BMW M2  [10.00]
Oh, and it is one piece, instead of two.
      10-11-2024, 01:12 PM   #7
RobM2
Drives: 2024 BMW M2
2024 BMW M2  [10.00]
rons e92 are you able to service the air filters without removing the CSL strut brace?
rons e921911.50
      10-11-2024, 01:14 PM   #8
rons e92
60-130 Enthusiast
rons e92's Avatar
I think you should be able to, but I had Eventuri intakes on my car. Someone else will have to confirm.
RobM2265.50
      10-29-2024, 12:46 PM   #9
RobM2
Drives: 2024 BMW M2
2024 BMW M2  [10.00]
Installing this now and the plastic shroud in the front is problematic.
rons e92 did you have to cut some of the plastic back?
      10-29-2024, 01:15 PM   #10
rons e92
60-130 Enthusiast
rons e92's Avatar
Are you talking about the shroud that covers the bolts on the strut towers?
If so, there is a black push style clip a little bit further forward that clips that black plastic cover to the body. It's round and has a pin basically stuck though a pin. Pull the center one up, it will then allow you to pull the whole pin out.
You can remove that to gain access to the bolts.
I just would bend mind and wedge the socket into there. I cracked one on one side which made it much easier.
I'm sorry, I'd sent you pictures, but I don't have an M2 currently.
If you're talking about something else, please send a photo and I'll try to help as best as I can.
RobM2265.50
      11-03-2024, 06:16 PM   #11
RobM2
Drives: 2024 BMW M2
2024 BMW M2  [10.00]
Ended up getting this installed no problem.
The CSL strut brace is a work of art. I had it powder coated:
      11-03-2024, 10:17 PM   #12
JABCAT
Professor
JABCAT's Avatar
4193
That looks great, especially powdercoated, but $2428 for a brace, no thanks.
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo full Merino interior.
His: '23 M2, Toronto Red Metallic, M highlight interior.
'11 Callaway SC652 Carbon Edition Corvette Z06. Inferno Orange Metallic. 1 of 3.
      11-04-2024, 11:16 AM   #13
RussV
Drives: 2024 BMW M2
Price seems a bit stiff (pun intended)
