09-06-2024, 08:32 AM | #1 |
Rep 172
Ok, so first, apologies in advance because I know this would have been talked to death already.
However, I have missed that conversation so I need to ask our informed M2 owners again. My M2 arrives in late December and of course I need to fix the ride height Can anyone please help or advise how I can measure spring performance so I can pick the spring that will accomplish what I want to achieve. My goals are: 1. Solid springs (not HAS) mainly for cost / value reasons as I don’t need any adjustability or want to ‘slam’ the car super low. 2. Conservative drop, nothing too crazy but maybe a 20mm drop for the OEM+ look and also to not cringe averytime I approach a speed bump. 3. Increase handeling performance. If I am going to change the spings for appearance I may as well make it count for performance as well. Does such a spring exists? If your not sure, how can I research? Should I be looking for a higher or lower spring rate than factory? |
09-06-2024, 12:17 PM | #2 | |
Rep 175
Good luck in your search. You will need an oil cooler skid plate because the oil cooler is as exposed as lady Godiva. I have an M240ix with ZTK and put a small hole in my oil cooler. Oil on my driveway led me to discover it with only 2 quarts lost, so no engine damage. However, a G87 owner and member picked up their car on the East Coast, was driving it back to the Midwest, got a low oil warning, pulled over and their engine was toast. The insurance company declared it a total loss. Turned out, something small had kicked up off the road and put a pretty small hole in the oil cooler, it was their 1st day owning the car. Mine was from rebar from a parking block that scraped the cooler when I was distracted. I bought the Turner Motorsports skid plate, which is very thick hardened aluminum, Mishimoto has one too. I know this is off topic, but it's related. |
dancing__narwhal185.00 |
09-06-2024, 03:50 PM | #3 | |
Rep 2,462
The perfect spring would be some time late May, not too hot and not cold either. Warm but with the recent rainfall, the grass is green and lush. And you know that summer is right around the corner so that always gets you excited too.
In terms of what you're looking for Quote:
1. HAS is around $1K, it's cheap for a high end product. KW is a great company known for their work in Motorsport. You don't have to slam the car either, you can simply lower it slightly and have a less roll in corners. 2. Again, you can simply lower it by 20mm if you want and not cringe every time you approach a speed bump. 3. The car will handle better on street and track with the KW system. It's designed for this particular chassis. You're buying a $70K plus car. Don't save a penny and lose a dollar with shit springs, just not worth it to ruin your car.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
reallymarkedup504.00 |
09-06-2024, 08:29 PM | #4 |
Rep 399
I think Eibach Pro-Kit is perfect for what you described.
Anyways, heres a link to the Non-Adjustable Springs Thread to help you out on your decision. |
T-Rexx219.00 |
09-06-2024, 11:56 PM | #5 | |
Rep 172
Thanks mate, I will check out the ecs link. The drop is perfect buts what’s the spring quality like? Is it like stock or better sport performance to stock? |
09-07-2024, 12:00 AM | #6 | |
Rep 172
As far as the KW HAS, you make a solid case! I will check out the price differences. I know springs are around $700 AUD, so if the KW HAS can be found for around $1500 AUD, I see your point and will propbly get those |
Bumpinjeep6039.00 |
09-07-2024, 01:51 AM | #7 | |
Rep 172
09-08-2024, 10:14 AM | #8 |
Rep 172
So I just realised I have posted this thread in the wrong forum. Sorry I am a newbie.
I meant to post it under wheels, brakes and suspension. Does anyone know how/if I can move it over there? |
09-09-2024, 06:30 PM | #12 | |
Rep 4,236
09-10-2024, 03:53 AM | #13 |
Rep 172
Dave07997S1068.50 |
09-10-2024, 04:05 AM | #14 |
Rep 172
ourlee1383.50 Dave07997S1068.50 |
09-10-2024, 04:52 PM | #15 | |
Rep 4,236
One thing I will say, is after lowering the car I got -2.0 deg negative camber in the front and almost the same rear. That has to help.
2024 BMW M2 Toronto Red 6MT
2020 Ford Mustang GT 6MT PP1 444rwhp (Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk Last edited by Dave07997S; 09-12-2024 at 10:43 AM.. |
BroDoze1726.50 |
09-10-2024, 05:10 PM | #16 | |
Rep 172
Exactly what I am looking for with it being a mild drop and for the spring to be slightly stiffer to prevent the strut/shock to bottom out now that it has less travel due to the shorter spring. |
09-10-2024, 05:36 PM | #17 |
Rep 4,236
Keep in mind that the European Part number (I don't know what you Aussies will get) Eibach drops the car more. You can order from a US provider if you want the US's more conservative drop. Mine is a US part #.
2020 Ford Mustang GT 6MT PP1 444rwhp (Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
T-Rexx219.00 |
09-10-2024, 06:01 PM | #19 | |
Rep 7,491
09-10-2024, 10:10 PM | #20 | |
Rep 172
I like your drop so it’s U.S spec for me. I don’t suppose you would know the U.S part number? |
09-10-2024, 10:12 PM | #21 |
Rep 172
09-10-2024, 10:25 PM | #22 |
Rep 2,049
To allow additional (lower) travel. The car would be slamming the bump stocks on bumps if they weren’t cut. Pretty typical for a lowering spring swap. There is less “room” to soak up big hits though. I bought the Eibach Pro kit, but I’m not 100% sure they’re going on the car. The gap is bad stock, but the roads here are worse. I wish there was a quality 10mm lowering spring option instead of the 20-25mm lowering springs.
///M
T-Rexx219.00 |
