      10-21-2022, 12:23 PM   #1
outlawAD
outlawAD's Avatar
123
Drives: over your lawn
Arrow M2 s58 vs. M3/m4 s58?
Anyone know the difference between the S58 in the M3/M4 and the M2? Is it just a tune to make less power in the M2 or something different mechanically?
      10-21-2022, 12:34 PM   #2
techniggo
Germany
255
Drives: G87 soon...
Just a tune
      10-21-2022, 12:39 PM   #3
Tag
this is the way
Tag's Avatar
19785
Drives: N-1 starfighter
The G80/2 have an S58O while the G87 has an S58T. There isn't much information on what the difference is between the two engine designations. That said, the S58 in the M2 is detuned to have 453hp which is only 20hp less than the base M3/4 which have 473hp. Torque however is identical for the G87 and G80/2 base models @ 406 ft-lb.
Check out this video when the BMW M2 Project Manager is asked specifically about the S58T vs the S58O engines.
Start watching @15m10s
lithe32.50
      10-21-2022, 02:07 PM   #4
outlawAD
outlawAD's Avatar
123
I kind of figured it was just a tune. Thanks
      10-21-2022, 03:29 PM   #5
GrannyShiftG80
GrannyShiftG80's Avatar
1349
Drives: G20 330i, G80 M3 6MT
So just a tune wil get me back to m3 comp power?
      10-21-2022, 03:54 PM   #6
moodyhank82
moodyhank82's Avatar
591
Drives: G05 45e & G87 6MT
In theory, but 6-speed transmission supposedly can only handle up to 406 lb-ft torque max so you will be running the risk of damaging your gearbox...
BMW CCA Member ID: 592739
      10-21-2022, 04:53 PM   #7
abdulisraddd
abdulisraddd's Avatar
Drives: 2025 G82 X IOMG
Can't wait to have 600+ wheel with just a jb4 and e30
lithe32.50
02M3ForMe4320.00
      10-24-2022, 03:34 AM   #8
rosemont83
Drives: 911 turbo, E39 M5,
This is the same transmission in the f8x and g8x? They can usually handle much more than that if so..
      10-24-2022, 06:49 AM   #9
serious_doubt
Drives: 2015 335i xDrive
Probably just additional wear on the clutch.
      10-24-2022, 08:57 PM   #10
Moflow
Moflow's Avatar
Drives: 2020 M2C 6MT
A G80 tune would still only have 406 lb-ft
Search this Thread:
Advanced Search
