BMW M2 Forums 2023+ (G87) iDrive, Nav, Stereo, Bluetooth, Electronics
      10-10-2023, 01:53 PM   #1
dmr
Drives: G87
K-CAN - easiest access?
Checked a lot of videos / instructions to gain access to CAN bus. Some go through dismantling passenger side trim, others center console.
I had a peek under my seat, see a twisted pair there.....
Basically, looking for easiest alternative to tap into the bus. All these look like a bit too much disassembling for my taste!
      10-12-2023, 06:29 AM   #2
DBV
DBV's Avatar
797
Drives: G87 M2, G20 330d, Brabus Smart
2023 BMW M2  [9.17]
2018 Brabus Smart  [10.00]
2021 BMW 330d  [10.00]
I'm not too familiar with the G87 wiring, but I'm planning on installing a Exhaust Valve Controller from PEEM Solutions. It's taps directly into the CAN at the fusebox, which is located in the passenger footwell. The install seems fairly straightforward, at least the access to the fuse panel. Not sure what you're planning on doing, but that may be the easiest route.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart
Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp)
dmr68.50
