06-25-2024, 03:30 PM | #1 |
Supreme Allied Commander
4090
Rep 55,797
Drives: F80 M3
EBC Redstuff Brake Pads BMW G8X M2 M3 M4
RedStuff Premium Low Dust Brake Pads
Part number: DP32089C DP32454C Redstuff is the EBC premium low dust pad for fast street driving on all types of cars and is even now available for truck and SUV with our ED range . When making the choice between Green, Red, Yellow, or even Blue grades for any vehicle. This pad selector chart is helpful; https://ebcbrakes.com/ebc-brake-pad-selector-tool/ Redstuff is an aramid fiber ceramic particle-enhanced premium brake material. We do NOTuse ceramic fibers in any of our pads. Redstuff is free of sulphides or lead and a low dust material, and fully ECE R 90 brake safety tested and approved. There is always “Some:” dust from brakes as they wear but the major advantage of the EBC range is that we use zero steel fiber in our pads and instead use less aggressive aramid fibers such as Twaron® and Kevlar® which are easy to wash off wheels and do not etch into wheel lacquers or alloy EBC Redstuff is also a long-wearing pad and as such takes approx 500Kms to fully bed down and show its full performance. To assist the bed-in, however, all EBC pads are surface coated with our Brake-in ™ pad brake in accelerator compound. PRODUCT INFORMATION High friction formula improves brake effect 15%. Tested at the UK Motor Industries Research Association (MIRA) in witnessed tests early Redstuff reduced car stopping distance in tests by almost 50 feet from 100 MPH offering a staggering 30% brake improvement. Redstuff ceramic brake pads, passenger car/saloon car pad NOT made for Truck or SUV fitments EBC lowest dust fast street pad with 15% brake improvement Capable of repeated heavy brake use without brake “Fall-Off” Very minimal disc/rotor damage characteristics Superb material for Prestige imports/European and Asian cars ECE R 90 type approved for most cars Features red “brake in’ surface coating for instant safe braking after install PERFORMANCE High Performance lowest dust rating pads for Prestige imports and faster street driving. There are two reasons our customers love Redstuff, First because they are the lowest dust pad we have encountered by reducing dust by 60-90%. Plus the minimal dust you see is very easily removed with a simple sponge wash as it contains no steel fibre particles as in all other pads. Second, they brake like an alligator right from cold (as good as Original pads or better) and just get better as they heat up. This material is an aramid fibre-based brake compound enhanced with ceramic particles. Made with Nucap NRS hooks on backplates to totally eliminate the chance of pad debond In stock and shipping now. Order here: https://hpautosport.com/product/ebc-...bmw-g8x-m3-m4/ Last edited by HP Autosport; 06-25-2024 at 03:48 PM.. |
07-15-2024, 12:10 AM | #4 |
4090
Rep 55,797
Drives: F80 M3
If you are looking for a Super Street and Track Day pad, take a look at the EBC Bluestuff NDX:
https://hpautosport.com/product/ebc-...dx-brake-pads/ |
08-29-2024, 11:30 AM | #13 |
4090
Rep 55,797
Drives: F80 M3
11-01-2024, 01:41 PM | #20 |
4090
Rep 55,797
Drives: F80 M3
Part number: DP32089C DP32454C Redstuff is the EBC premium low dust pad for fast street driving on all types of cars and is even now available for truck and SUV with our ED range . When making the choice between Green, Red, Yellow, or even Blue grades for any vehicle. This pad selector chart is helpful; https://ebcbrakes.com/ebc-brake-pad-selector-tool/ Redstuff is an aramid fiber ceramic particle-enhanced premium brake material. We do NOTuse ceramic fibers in any of our pads. Redstuff is free of sulphides or lead and a low dust material, and fully ECE R 90 brake safety tested and approved. There is always “Some:” dust from brakes as they wear but the major advantage of the EBC range is that we use zero steel fiber in our pads and instead use less aggressive aramid fibers such as Twaron® and Kevlar® which are easy to wash off wheels and do not etch into wheel lacquers or alloy EBC Redstuff is also a long-wearing pad and as such takes approx 500Kms to fully bed down and show its full performance. To assist the bed-in, however, all EBC pads are surface coated with our Brake-in ™ pad brake in accelerator compound. PRODUCT INFORMATION High friction formula improves brake effect 15%. Tested at the UK Motor Industries Research Association (MIRA) in witnessed tests early Redstuff reduced car stopping distance in tests by almost 50 feet from 100 MPH offering a staggering 30% brake improvement. Redstuff ceramic brake pads, passenger car/saloon car pad NOT made for Truck or SUV fitments EBC lowest dust fast street pad with 15% brake improvement Capable of repeated heavy brake use without brake “Fall-Off” Very minimal disc/rotor damage characteristics Superb material for Prestige imports/European and Asian cars ECE R 90 type approved for most cars Features red “brake in’ surface coating for instant safe braking after install PERFORMANCE High Performance lowest dust rating pads for Prestige imports and faster street driving. There are two reasons our customers love Redstuff, First because they are the lowest dust pad we have encountered by reducing dust by 60-90%. Plus the minimal dust you see is very easily removed with a simple sponge wash as it contains no steel fibre particles as in all other pads. Second, they brake like an alligator right from cold (as good as Original pads or better) and just get better as they heat up. This material is an aramid fibre-based brake compound enhanced with ceramic particles. Made with Nucap NRS hooks on backplates to totally eliminate the chance of pad debond |
