BMW 2 Series Technical Topics (G42) Cosmetic Modifications (Exterior, Interior, Lighting)
      10-05-2022, 04:20 PM   #1
XC3LLR8
Drives: Super73
BEWARE of Chemical Guys Water Spot Remover
Ordered the Chemical Guys Water Spot Remover to clean up…well, the obvious. I read the instructions and followed them carefully before beginning and made sure it didn't mention anything about not using on mirrors, as that's where I was beginning.
Thankfully I only did one mirror (passenger side) before moving on. For some reason it left a heavy haze on the inner-third of the mirror. I tried getting it off with water, then water and soap, and then vinegar, all with no luck.
I ended up calling Chemical Guys and told the employee what happened and he said, "Yeah, there are some outside mirrors it shouldn't be used on." I politely stated it would've been nice if the instructions had stated that. He put me on hold to speak with someone else and came back suggesting to reapply it and quickly neutralize it with water and if that doesn't work try wax cleaner.
I did the reapply, neutralized it, and no change. I then got out the Meguiar's Ultimate Compound and rubbed it in with a soft cloth, followed up with Meguiar's Mirror Glaze and that FINALLY did the trick.
Now I'm not comfortable using the Chemical Guys Heavy Duty Water Spot Remover anywhere else on the car, but their Synthetic Quick Detailer has been great.
TJZ67201877.50
PP3121373.00
viperx100680.50
      10-05-2022, 05:04 PM   #2
inc235
Drives: 23 M240i RWD
That is interesting that it etched the mirror's glass surface.
Knowing that it can potentially etch surface, I'd approach with caution on painted surfaces as well.
IMO, polishing glass surface is usually good enough to remove water spots. But in general, how I think you should fix the blemishes are going gradually from weaker stuff to stronger stuff until you see an effect (wax -> compound -> heavy duty stuff).
      10-05-2022, 05:26 PM   #3
XC3LLR8
Drives: Super73
I agree, and I failed to mention that. First I used the Mirror Glaze and it only fixed it to maybe 80%. The Ultimate Compound took it home, and then I reapplied the Mirror Glaze just for a finishing touch.
Prior to finally getting it fixed with the Meguiar's I was on hold with the BMW parts department thinking I would have to replace the mirror, but they were backed-up and I finally hung-up. That's when I tried the Meguiar's only because it was already in the garage cabinet. Thankfully it worked!
      10-05-2022, 05:39 PM   #4
XC3LLR8
Drives: Super73
Now that's it's been about an hour since using the compound I'm seeing maybe 20% of the haze still there - is it slowly creeping back?
I've read where people have had luck using a small polishing wheel, so it makes me feel better knowing that while it may not be 100%, it can at least get there...eventually.
      10-05-2022, 05:46 PM   #5
inc235
Haze coming back when dry likely means more etched surface needs to be buffed/polished out! LOL. A bit more elbow grease but hopefully it is back to 99% of original state
XC3LLR82086.50
      10-05-2022, 06:13 PM   #6
NoSuchSol
Drives: 23 G80 Yellow
Most chemical guys products are pretty good. I didn't like their glass cleaner - it was similar in that it left a heavy haze that was difficult to get off.
Water spot removers can be pretty intense so I wish you the best of luck. The goal is to make life easier and some of these are just too intense. =\
      10-05-2022, 07:13 PM   #7
DrRBui
Drives: 2023 M240i
I had a look at the SDS. Chemical Guys are surprisingly transparent about their formulations. No surprise why it etched your glass - the main ingredient is ammonia bifluoride which produces HF the most common etchant for SiO2 surfaces such as glass.
I'm actually surprised they're able to sell this as a DIY product. HF down the drain is a big nono,
XC3LLR82086.50
jbazz258.00
      10-05-2022, 07:50 PM   #8
DrJLag420
DrJLag420's Avatar
Drives: 2022 BMW M240i
That's some harsh chemicals. Wouldn't let that touch any of my cars. I'll stick with Griot's, Xpel, and STEK detail products.
      10-05-2022, 08:16 PM   #9
ryo-
Drives: '22 MWM M240i
what's a good product to remove water spots (stains?) on the glass black trim? I was washing my car today and noticed that the markings don't come off at all, even with hard rubbing w/ soap and detailer spray.
      10-05-2022, 08:20 PM   #10
XC3LLR8
Drives: Super73
A combo of vinegar and water is supposedly to go-to formula.
I'm still rubbing compound on that one mirror as the haze (a little more diminished each time) keeps coming back. So glad I didn't let it touch anything else. Really surprised at how many good reviews it has.
      10-05-2022, 08:22 PM   #11
DrRBui
Drives: 2023 M240i
Add a tiny bit of acid such as vinegar to your usual car wash soap. Water spots are usually just leftover soap and minerals from washing or use. Add it to the rinse fluid for good measure.
      10-05-2022, 08:25 PM   #12
DrRBui
Drives: 2023 M240i
Looks like we're thinking the same
For your problem - I'd use something silicone based or labeled as a ceramic. The SiO2 will restore the ectches in the mirror and then you should just polish until restored.
XC3LLR82086.50
      10-05-2022, 08:29 PM   #13
XC3LLR8
Drives: Super73
Are you suggesting a ceramic-based wax? Any specific name/brand you recommend?
      10-05-2022, 08:33 PM   #14
DrJLag420
DrJLag420's Avatar
Try Griot's Ceramics
https://www.griotsgarage.com/ceramic-all-in-one-wax/
https://www.griotsgarage.com/ceramic-3-in-1-wax/
XC3LLR82086.50
PP3121373.00
      10-05-2022, 08:42 PM   #15
DrJLag420
DrJLag420's Avatar
Try this. Best used with a random orbital. But can be used by hand as well. Will take a bit more time and effort though.
https://www.griotsgarage.com/one-ste...ant-16-ounces/
ryo-268.50
      10-05-2022, 08:47 PM   #16
DrJLag420
DrJLag420's Avatar
The ultimate way to keep those piano black trim pieces swirl free and easy to keep spot free is self healing PPF. Not cheap but well worth it IMO
PP3121373.00
viperx100680.50
      10-05-2022, 08:58 PM   #17
DrRBui
Drives: 2023 M240i
DrLag gave some good suggestions. I'd go with any of his
DrJLag420842.00
      10-06-2022, 01:09 AM   #18
inc235
Yup definitely will produce some amount of HF (very little) with sulfuric acid. No wonder it etched auto glass surfaces LOL.
      10-07-2022, 07:58 AM   #19
Ruebarb
Ruebarb's Avatar
417
Drives: BMW G42 M240i
I've had no luck removing the factory issued water spots in the mirrors, straight vinegar did nothing.
Anyone have success?
      07-08-2024, 12:58 PM   #20
IcEWoLF
Drives: M340 XDrive
I’ve had the same issue. Don’t use it on glass.
Had to use some heavy compound to get that removed. Took several tries.
      07-08-2024, 03:20 PM   #21
Littlecoupe
Drives: 2023 M240i
I still have water spots that need to be addressed. I'm not sure if they were factory installed, or if I did not rinse off the cleaners quickly enough when I took delivery...partially in the sun (it was cloudy prior). I've never made that mistake before.
I tried CG Spot Remover, it did absolutely nothing to fix my issue. I did a full polish, which helped, then a single pass compound then polish, better but not perfect. Once my sealant is worn off (yes, stupid to apply sealant over an imperfect surface), I'll tackle again with more passes of compound to get it perfect.
