M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > MPE - replace remote with wired solution?
      10-18-2021, 11:46 AM   #1
adzik
Drives: BMW M2 F87
So I have a F87 M2 with M Performance Exhaust installed.
And I hate the remote
It works fast and reliably maybe 90% of the time. This sounds a lot, but not enough to rely on it enough to just fire and forget. I always need to double check.
And also because it doesn't have a good storage place it's not really convinient enought to quickly open the valves when I enter the tunnel. And that's a serious usecase!
Anyway.
Do you have a solution to open the valves in a more reliable way?
I was thinking about buying a panel from F20 1 Series with a PDC button and somewhow repuropse it to the valves control.
But boy the more I think of it, the more ghetto it sounds...
Maybe you have some other ideas?
      10-18-2021, 09:44 PM   #2
Pottah
Drives: 2019 LBB M2C
You can use this and program the home link buttons. You can also order one with the default “open” you’ll never have to worry about it.
https://x-ph.com/cg-precision-vsc-2-...nd-controller/
      10-18-2021, 09:56 PM   #3
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
This bothers me as well. I wish there was a wired solution.
The Bluetooth controller works OK, most of the time, but I'd rather have a button on my dash that is hardwired and not have to worry about wireless.
Honestly, I could probably build something myself, but haven't really spent much time thinking about it.
2018 M2 - Daily Driver/Track Car
Motorcity BMWCCA Member
Instagram | YouTube
      10-19-2021, 02:50 PM   #4
ming_lau
Drives: F87 M2
The stock exhaust has only 1 valve motor and on CG’s website it shows VSC-1 is the correct one. However, the MPE for M2 has two valve motors. The VSC-2 is designed for M2C, M3, and etc per CG’s website. Knowing thar M2C’s exhaust value are controlled by wire to start with, not sure the VSC-2 will work on the BT controller setup. Trying to verify if the VSC-2 is indeed the correct one but had little luck so far. Do you have VSC-2 installed on yours?
      10-19-2021, 06:55 PM   #5
Pottah
I have a stock M2C exhaust and the VSC-2 works perfectly. Not sure about your scenario just a suggestion. Call the manufacturer or a reseller to find out.
      11-30-2021, 04:38 PM   #6
adzik
Drives: BMW M2 F87
Can you "see" the valve control from the OBD point of view?
What I mean is - is it even possible to code this somehow?
I know that the valves are operated by their own logic board in the trunk... but maybe this could be at least aligned with how previous modes operated?
      12-01-2021, 01:58 PM   #7
mr_lab_rat
mr_lab_rat's Avatar
566
Drives: 2017 M2, 2018 X1
I have been thinking about reverse engineering the control module. There are bunch of unused pins. If we are lucky just shorting couple of them will do what we are trying to do. I will keep you posted.
Meanwhile I cut the foam pool noodle to create an insert into the door bottle holder. That works pretty well for holding the remote.
      12-01-2021, 02:25 PM   #8
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
I will be trying the VSC-2 without using the MPE electronics (I will use the stock valve cable) and will report back what I find!
OG M2 with the OEM M mirror retrofit
      04-07-2024, 11:47 PM   #9
Damage Inc
Damage Inc's Avatar
809
Drives: 2017 M2
Did this work??
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS
      04-07-2024, 11:48 PM   #10
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
Originally Posted by Damage Inc View Post
Did this work??
Never got around to trying it because I switched to Remus but I don’t see why it wouldn’t work!
      04-08-2024, 01:38 PM   #11
Damage Inc
Damage Inc's Avatar
809
Drives: 2017 M2
I'm about to order and try it. Right now I manually go to the trunk to open the valves by disconnecting the MPE module lol. Its not very efficient.
      04-08-2024, 10:54 PM   #12
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
lol yeah I just got so sick of the MPE that I dumped it - if you get it for cheap, it’s worth it. Feels bad for those that paid MSRP haha
m2
