09-18-2008, 07:51 PM | #1 |
Rep 4,649
DIY: Changing Air Filter/Installing AFE Air Filter for E9X M3's w/Pics
Install was pretty easy. Anyone with basic mechanical know-how can do it in about 15 minutes.
Tools Needed: Torx screwdriver size 20 Flathead screwdriver 1. Locate the air box. You'll find 8 Torx 20 screws that hold it on. Use your Torx 20 screwdriver to loosen the screws. It is not necessary to completely remove the screws, just unscrew them enough so it gets loose (it'll help you keep track of your screws too! ) Be careful and try not to drop any screws deep down into the engine compartment because it's not fun to fish them out. 2. When all the screws have been loosened, pull off the air box cover. Easiest way is to pull up and to the right. 3. Loosen the clamp around the rubber intake. 4. Now you're ready to remove the filter. To the right of the filter is a piece of plastic that sticks out with a rounded end. That's a tensioner. Now all I did was pull up (you might have to give it a little elbow grease) and it came right out. The piece of plastic that connects the intake to the filter will probably come off with the filter too. 5. Reinstall the plastic piece to the intake. Ensure that you got it on properly. Tighten the clamp until its snug. 6. After everything looks good, begin to slide in the replacement filter. Depress the tensioner and install the filter. Some tensioners are looser than others, if yours doesn't give very much, just push the filter in. After the filter is in, ensure that everything is lined up properly and snugly. Finished Product 7. Now you're ready to put the cover back on. Make sure you fit the cover back on the way it's supposed to be...specifically tucking the cover under this plastic duct piece: 8. Screw all the screws in and viola! All done. Enjoy! Last edited by Blake; 05-05-2009 at 12:25 AM.. |
09-18-2008, 08:06 PM | #2 |
Love my car!
11
Rep 78
Nice job! Now, where can I find that filter? It doesn't show up in the search on their website...
2018 M240i xi (LCI) | Estoril Blue | Dinan Stage 1
09-18-2008, 08:33 PM | #4 | |
Rep 4,649
09-18-2008, 09:30 PM | #5 |
Rep 1,035
Interesting. I wrote a DIY here. Torx size is actually T-25. T-20 fits but will strip it if you are not careful. I also found it easier to disconnect the rubber pipe at the other end, but there's always more than one way to skin a cat.
09-18-2008, 10:44 PM | #6 |
Bored at work....
891
Rep 5,393
Nice writeup. Now I have to go get a set of Torx!
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
09-19-2008, 12:14 AM | #7 | |
Rep 4,649
09-24-2008, 12:39 PM | #9 |
Bored at work....
891
Rep 5,393
12 minutes flat.....such a simple upgrade.
09-25-2008, 10:57 PM | #10 |
Rep 577
quite simple.... but just a word of caution, the edges of the inside of the plastic are quite sharp... got a nasty slice on my palm trying to pull out the old filer.... be careful.... CHeers
"What a car.... what a masterpiece...." Jeremy Clarkson on the E92 M3
2008 Alpine White E92 M3 2019 Mineral Grey i3 REX |
09-25-2008, 11:57 PM | #11 |
Love my car!
11
Rep 78
I got mine and installed it yesterday. Didn't notice much until I was driving around at night - no radio or A/C on - and when I got into the throttle I could hear the air being sucked into the hood intake... very cool!! I didn't even have my window open...
09-26-2008, 12:37 AM | #12 |
Supreme Allied Commander
3886
Rep 54,510
Drives: F80 M3
09-26-2008, 12:41 AM | #13 |
Bored at work....
891
Rep 5,393
Send me a ticket!!
09-28-2008, 09:49 PM | #14 |
Rep 2,008
Whoa whoa whoa, you can tell the difference by just changing the type of filter?
Does this provide documented increases in air flow? I'd consider buying it just for the sound.
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe (Past): 2016 F30 340xi M-Sport -2013 535i xdrive 2008 E92 M3 - 2006 E90 325i 2002 E46 325xi - 1991 E30 325i |
09-28-2008, 10:07 PM | #15 |
Love my car!
11
Rep 78
I can't feel any difference in power, but the sound is definitely different.
I can't say whether the stock filter made the "air intake" sound or not because I wasn't listening for it before. It definitely does now though, and it's pretty cool!
09-29-2008, 02:15 AM | #16 | |
3886
Rep 54,510
Drives: F80 M3
The sound is just an added benefit! |
09-29-2008, 08:05 AM | #17 |
Ground Pilot
41
Rep 548
Drives: e92 BMW M3
I agree with that.
"The laws of physics cannot be repealed, even with DSC." - BMW Owner's Manual
11-10-2008, 04:40 PM | #18 |
Rep 1,291
Received the Dry version this morning and followed the DIY guide got it installed earlier. Will drive a bit later see how much difference it makes. Installation is not difficult, but not as easy as I expect or I am just not handy enough.
Must stop eating..............
11-28-2008, 08:56 PM | #19 |
Rep 203
installed the dry version today. Had to re-install it twice because i kept getting a rattle during hard acceleration. BUT its still doing it! guess i'll just have to try again.
12-02-2008, 12:13 PM | #20 | |
Rep 194
There is a slight rattle as you accelerate and then it goes away. |
12-02-2008, 05:04 PM | #21 | |
salivator
38
Rep 539
I have the exact same issue. I keep thinking that the filter is not completely flush with the intake, and that it is letting unfiltered air to flutter into the intake, causing the rattle noise. Does everyone experience this sound under load? |
12-02-2008, 10:46 PM | #22 |
Rep 203
i tripled checked all the fitment every time i reinstalled it (thrice). Im 99% sure its just the sound of air turbulence going through the intake. I even did a back to back swap of the stock and AFE filter and noticed if you listen really close even the stock filter makes the fluttering noise between 3-4 rpm during hard acceleration.
