BMW M3 Forum (E90 E92)
Mporium BMW
      12-24-2008, 03:53 PM   #1
SS32
SS32's Avatar
156
Drives: 2008 M3
Arrow DIY: Clutch Pedal Spring Removal DIY
Took ace996's instructions and took some pictures for anyone interested. The hardest part was removing the e-clips, but the right tools help.
Tools used:
T-25 Torx Driver
Flashlight
Various Bent Picks
Tom's Instructions
Originally Posted by ace996 View Post
I forgot to take pics of this...but my description should be sufficient...it is quite easy.
Ditched the clutch-spring today...about 5 minutes total. You need a little torx bit and something to pull two little e-clips...I used a curved pick.
1. Under the steering wheel, there are three little screws you need to remove, this allows the plate/cover that shields the pedal-innards to be removed. Once they are out, the plate/cover drops down...just watch the wires.
2. Behind the clutch pedal, there is a spring...it looks like a little black coilover...that is what is removed, not the silver spring that pulls it up in front (closer to the driver). You need to use the pick, or something else, to pull the e-clips that are on the left-side of the restraining pins (the top and bottom of the coilover).
3. Push the pedal, by hand, all the way to the floor and push the locating pins (top and bottom) out. This will allow you to pull the top of the coilover out and then the bottom.
4. Put the cover back and install the three screws. That's it.
I've done this to all the cars I've owned over the past few years. What this does is give a consistant feel to the pedal on release. You know how the pedal feels hard at first when you push down, then it gets easier? Now it's just the same feel the whole way down...not really harder...but it doesn't get easier.
The real reason for this... when I release the pedal, you can feel the engagement point much better, instead of the wandering/vague point with the spring. I never feel comfortable with the spring installed, as it feels as if the engagement point is never quite same from one day to the next. Now, the lever release is linear...no change in pressure from one inch to the next.
Depending on how I feel, I may tackle the clutch-stop mod next...
Be good,
TomK
Under the steering wheel you'll find a plastic cover with 3 T-25 screws. Remove these and drop the cover down.
Once you drop the cover down, it helps to detach this connection so you'll have more room to work. I'm not sure what it is, but it comes off easy enough. Just push the tab on the right side and it slides out.
e-clip on the left side of the top retaining pin
e-clip
e-clip on the left side of bottom retaining pin with scratch marks from me trying to remove it
Picks I bought at Advance Auto
This is definitely worth the 10 minutes that it takes. The clutch feels so much more linear. It doesn't pop out at the top of the travel like it used it. If you have even the slightest thought about taking the spring out, do it.
Scharbag2634.00
Remonster824.00
      12-25-2008, 12:37 AM   #2
ace996
NASA/PDA Instructor
ace996's Avatar
Drives: E92M3
Phenomenal write-up!!! Great job and glad you like the change.
Be good,
TomK
"Arcadian, I've fought countless times, yet I've never met an adversary who could offer me what we Spartans call "A Beautiful Death." I can only hope, with all the world's warriors gathered against us, there might be one down there who's up to the task."Μολὼν λαβέ!!
      12-25-2008, 04:15 PM   #3
V1.47fan
Drives: TheArtist formerly known as M3
Thank-you! guys.
      12-28-2008, 12:11 AM   #4
mach330
You don't know JACK!!!
mach330's Avatar
43
Drives: 2011 X5 35i
awesome...gonna try this tomorrow.
Rated /// M
      02-17-2009, 06:10 PM   #5
tunawi7cheese
tunawi7cheese's Avatar
Drives: Power by dead dinosaurs
What's the point of this mod? I don't know what the clutch pedal spring does? Can someone please explain?
      02-17-2009, 11:01 PM   #6
endofanera7
endofanera7's Avatar
Drives: 08 JB E92 M3
I did the same thing and the clutch def feels much better! Great DIY.
      03-29-2009, 02:11 PM   #7
schnell325
Bored at work....
schnell325's Avatar
Drives: 2016 F82 M4 GTS//2022 M235iGC
Awesome!!! Just did it and the clutch feels much better, no "click/pop" upon release.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      03-31-2009, 11:23 PM   #8
busman76
busman76's Avatar
10
Drives: E90 M3 AW/Fox
did mine tonight took like 10min and it feels awesome. I agree definitley no pop at the top.
08 E90 M3 AW/FR/ 6 speed/Prem/H&R/Macht Schnell Air Filter/B&W Roundels/ Monochrome Badging/ Black Kidneys/ black grilles/ clutch pedal spring removed,painted reflectors,AA Pulley.
On order: Macht Schnell Spacers 15/12, GP Thunders,
      04-12-2009, 12:14 PM   #9
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
this is a nice idea until you realize you need an acrobat midget to accomlish this. I cant even see the clips to be removed. i can barely reach in and feel where they are so after half hour of messing around put it back together until my midget acrobat shows up to help.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      04-16-2009, 08:03 PM   #10
jdogg2000
jdogg2000's Avatar
26
Drives: 2011 Carrera GTS
I also thought this was a PITA to do because it took me a while to find a good position to get the upper clip off while holding my light. I ended up lying down upside down on the driver's seat hahah. It was worth it though as it changes the clutch feel immensely. It is MUCH easier to shift smoothly when shifting quickly. Highly recommended, a little pain for a big benefit!
      04-20-2009, 09:00 AM   #11
SS32
SS32's Avatar
156
Drives: 2008 M3
I'm 6' 2" and got it done. It's not the easiest place to work, but it's definitely possible.
      04-20-2009, 10:04 AM   #12
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
i am going to try again shortly as i have a track day coming up. I just wasnt in the mood to mess with this that day i guess.
      04-21-2009, 07:44 PM   #13
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
got this done today. Havent driven the car yet so unsure if it will be something i like. Also my car uses a t-15 for those screws to get the cover off not a t25. mabe i need more drive time but each time i drive the car i forget i even changed anything so dont think this mod does much.
      05-15-2009, 09:27 PM   #14
ace996
NASA/PDA Instructor
ace996's Avatar
Drives: E92M3
...put it back in and see if there's a difference...
      06-09-2009, 12:19 AM   #15
aremmell
aremmell's Avatar
125
Drives: '24 M4 Comp xDrive
Interesting mod. Why would the engineers put the spring in at all if it feels better without it?
      08-04-2009, 09:01 PM   #16
JohnnyRoaster
JohnnyRoaster's Avatar
Drives: 09 Jerez Black M3 Sedan
I did this today and love it. It makes for much faster and smoother shifts. The short shift kit is next. A couple of words about the removal. It is a t15 for the screws. I used a set of ring pliers instead of dental picks. It was really hard to get the lower ring but I did not have to employ any left handed acrobatic midgets. I used a small handheld mirror to see the lower lock ring. It was tricky but at six three a better option than standing on my head backwards with my feet over the drivers seat.
      08-05-2009, 03:25 AM   #17
endofanera7
This is the question I've been wondering this past couple of days. My shifting is almost perfectly smooth every single time now I have 15000 miles on the car.
Im thinking of putting the spring back on to see if there's any significant change in my shifting behavior.
For those who did this mod a while back, what's your plan?
      08-05-2009, 09:17 AM   #18
John@BMW
I can't belive this car is a 4 door family sedan.
John@BMW's Avatar
66
Drives: 2008 M3 sedan, '96 M3
Remember- this clutch spring is designed to help you push the clutch pedal in and keep it to the floor.
Could everyone post a picture of your clutch springs out of the car?
BMW has a newer updated Dual spring design out now that changes the feel and feedback from the clutch pedal.
When i did the 'swap' to the updated spring, the clutch pedal felt much better and linear than before. The earlier version changed pedal effort almost halfway down which gives you a false impression of clutch engagement/disengagement. The new spring does not seem to do that any more-
Picture-
Right side is the newer updated unit. The left side is the original factory '2008' spring
      08-05-2009, 09:20 AM   #19
DevJ
DevJ's Avatar
Drives: R8 V10+/YMB M4
John,
How would I go about getting one of these? Thanks
‘23 RRS First Edition
'22 X7 M50i
'18 R8 V10+
http://www.bimmerpost.com/forums/attachment.php?attachmentid=133578&d=1204654487[/IMG]
      08-05-2009, 10:02 AM   #20
roofone
Drives: 09 E90 M3
I've got the newer two spring setup pictured on the right. 6/09 build.
I'm glad you posted this. I did the clutch spring removal mod this weekend and didn't like the feel - it was too abrupt. Good to know there's a difference.
Maybe I'm just not very good at shifting, but the clutch just feels perfect with the spring in -- I think I'll be putting it back in this weekend.
      08-05-2009, 10:24 AM   #21
John@BMW
John@BMW's Avatar
66
Originally Posted by DevJ View Post
John,
You need to order part number: 35-00-6-769-442
That is the newest updated spring!
      08-05-2009, 10:27 AM   #22
SlammedR8
SlammedR8's Avatar
Drives: 2019 X5 40i/2020 R8 V10 Spyder
you guys think we could get our service department to change this piece without charging? If the original piece sucks?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
m3post
