BMW 2 Series Technical Topics (G42) Suspension / Brakes / Chassis
      10-22-2022, 12:32 PM   #1
NoSuchSol
Drives: 23 G80 Yellow
Supra strut bar - yes or no?
https://www.evasivemotorsports.com/s...upra-a90-2020/
Would something like that fit the G42? I'm under the assumption that the two side strut braces fit either car but is the distance between the two strut towers the same?
      01-16-2023, 10:03 PM   #2
Dinosoar
Enthusiast
Dinosoar's Avatar
Drives: 2022 230i M Sport
2022 BMW 230i  [0.00]
I like it, but no way, IMO, that main bar or those brackets fit under the hood.
      02-04-2023, 10:52 AM   #3
dszpiro
dszpiro's Avatar
Drives: 2022 M240iX
2022 BMW 330iX  [0.00]
2022 BMW M240iX  [0.00]
Dinan offers a strut bar for the G42:
https://www.dinancars.com/products/s...arts/D180-0014
It does not go across the towers so some have questioned the effectiveness of this sort of strut brace.
BMW #9: 2022 M240ix (Dec 2021)
BMW #8: 2022 330iX (Dec 2021)
Past: 320iX, M550iX, M235iX, 335iX, two Z4, 540i
      04-14-2023, 02:41 PM   #4
desertspotter
Drives: F22 coupe
I bought G22 OEM parts to install it in a OEM+ modification style.
There are several posts in g20 forum
https://g20.bimmerpost.com/forums/sh....php?t=1810482
For sure it's one of the cheapest options, both strut bar, the front bar (the g20 and g42's one doesn't have threads for bolts) and all the bolts cost me about 200$ (180€).
      04-17-2023, 04:24 PM   #5
dszpiro
dszpiro's Avatar
Drives: 2022 M240iX
I have tried to carefully compare the photo from the Supra strut bar you linked to the Dinan strut bars for the G42. Aside from the mounting points and other dimensions, I don't think the Supra bar will make it over the engine cover. The photos make it look like the G42 mounting points on the tops of the towers are lower compared with the top of the engine cover than the Supra set-up. What do you think?
      05-18-2023, 09:04 AM   #6
MorendiSLO
Drives: M240i xdrive g42 , AUDI TT RS
Installed OEM ones, took me 20min
      05-18-2023, 09:41 AM   #7
dszpiro
dszpiro's Avatar
Drives: 2022 M240iX
Looks good! When you say "OEM ones", do you mean these are BMW parts? If so, do you have the part number?
Thanks!
Nate48157.50
      05-19-2023, 05:49 PM   #8
desertspotter
Drives: F22 coupe
Thanks!
I did the same mod.
they are G22 OEM parts, part numbers are:
Strut : 51617456115 x2 stock are bare metal, you can paint it if you want
Bolts : 51716966566 x4
The front brace don't have the nut so you need to change also the front brace to the G22 one ( p/n: 51648491817 + required bolts 07147270121 x4 ) or use a rivnut o just a nylon nut to install it.
Also you will need to tap the strut hole (M10x1.5)
Replacing the front bar the hardware is less than 200$ and installation it's pretty straight forward.
dszpiro55.00
koopa223.00
      09-19-2023, 10:34 PM   #9
Ruebarb
Ruebarb's Avatar
417
Drives: BMW G42 M240i
Did that include swapping the front bar with the threaded holes?
Originally Posted by desertspotter View Post
I did the same mod.
I'm looking to do the full swap of the front bar, any issues since doing this. I can't see why their would be. Figured I'd ask or anything that was a pita in the removal, I've watch the video of the guy for the M340. Thanks
      10-02-2023, 03:03 PM   #10
SpecTaqlar
Romania
15
Drives: G42 M240i
I can vouch for your investigation first hand - the strut tower mounts are lower on the G42 than on the supra , there is no way to mount it without some adjusting . I've got a blitz strut brace , and for the strut mounts i used some stiffer rubber washers that i pretty much sandwiched between the strut mount and the brace at not even 30Nm. If i pull on the brace there seems to be 0 movement and the whole car shakes , but i am aware that using rubber anywhere in a strut-brace install pretty much negates the use of the brace so i just accepted its faith as engine bling. It does look nice , and in probably what is pure placebo , i feel like the structure around the engine is stiffer , and therefore the frontend very slightly so better.
dszpiro55.00
      12-16-2023, 12:55 AM   #11
Xlastar67
Drives: BMW G42 M240i XDrive
So is this strut bar on a BMW, or Supra?
      12-21-2023, 03:14 AM   #12
Bee Pee
Bee Pee's Avatar
United Kingdom
1949
Drives: AW M2 DCT
Turner Msport brace if budget allows
https://www.turnermotorsport.com/p-2...rut-brace-kit/
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      12-22-2023, 03:59 AM   #13
SpecTaqlar
Romania
15
Drives: G42 M240i
I think the question was for me, right ?
It's a bmw - g42 m240i xdrive.
      04-22-2024, 05:41 PM   #14
SpeedGeek
Drives: 2024 M240i xdrive
OEM Strut Bars
Cheers,
New to the BMW world but not to car modding, happy to have a turbo back under the hood. It all started with a 95 Eclipse GSX, then a G35, now this!
My first bolt-on while I wait for Dinan intake parts to show up was the OEM Strut bars. BMW (51-61-7-456-115) x2 I used stainless rivet nuts for the front (M10 Stainless Steel Rivet nuts M10-1.5mm Threads) and beveled a lip if I need to remove that aluminum plate, then tap’d the rear holes Metric Thread Tap,M10 Right Hand Thread Tap (M10x1.5) M10 Stainless Bolts and washers
The entire process took maybe an hour, going slowly – It was pretty easy. I polished the bars for bling. I purchased the bars from getbmwparts.com
Love this car, still 600 miles into break in - Maybe this info will help anyone interested. Great Forum!
      05-07-2024, 12:04 PM   #15
J-RO
Drives: 2024 M240ix BMW X1 28i
Too bad they just dont make a plain one and not CF.
      05-07-2024, 12:48 PM   #16
J-RO
      05-07-2024, 02:01 PM   #17
Pentland
Drives: BMW M240i (G42)
Shame it doesn’t seem to be available in the UK.
I’d have that in a heartbeat!
Edit: just emailed them and they do ship to the Uk!
      05-24-2024, 03:49 PM   #18
Pentland
Now fitted…
kudos183.00
      05-25-2024, 03:07 AM   #19
I Lupi 16
Drives: 2022 M240i
Do you all think the strut bars that use a screw and nut are as sturdy / give the same benefit as those who add the front brace from the g22 to secure the bars?
      05-29-2024, 12:22 PM   #20
AlexC2er
AlexC2er's Avatar
Drives: G42 M240i RWD
Originally Posted by Pentland View Post
Now fitted…
Can you share a bit about how it affects the handling?
      06-18-2024, 01:12 PM   #21
Antique-ace
Antique-ace's Avatar
Drives: 2022 M240i xDrive
I installed the factory strut bars last weekend. I was surprised that I did not need to use the spacers that came with the Dinan intake. The strut bar had about 3/16" clearance at its closest to the intake cover without the spacer with no rubbing.
2022 M240i xDrive | Thundernight Metallic, Black Vernasca w/Blue Stitching |
SOLD: 2011 (F10) 550i xDrive; 1995 (E36) M3 Coupe.
      06-18-2024, 01:28 PM   #22
Antique-ace
I asked myself this same question before installing the strut bars. I decided to use 304 stainless M10-1.5 rivet nuts. Seems to be sturdy enough to me. I figured I can always buy the factory threaded crossbar if I decide this isn't good enough.
https://www.amazon.com/dp/B0CMQR2TTL...t_details&th=1
