04-04-2024, 02:26 PM | #1 |
Rep 25
Drives: 2024 M2
Sirius XM & Carplay text messages
ok here is my first world problem, anyone have any suggestions
- I have carplay activated and I use Waze (so don't want to disable carplay as a solution) - I have a 2.5 hour commute so typically listen to the radio for a while then switch over to Sirius XM - iDrive buffers about an hour of the Sirius XM channel you are on so I typically use the jump back to get to the beginning of the buffer then use jump forward to skip boring segments etc - however, if i get a text message the Sirius XM channel skips to live playback; i can of course jump back but if the segment i was listening to was 20 minutes long i can only jump back to the start of the segment not where i left off when the text message came in a couple of generations ago idrive had true ff and rewind but that seems to have disappeared and you can only go from segment to segment. |
04-05-2024, 10:47 AM | #3 |
Rep 25
Drives: 2024 M2
yeah that's what i'm afraid of, was just hoping maybe someone had a workaround but it is such a corner case as you point out
