BMW 2 Series Technical Topics (G42) Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      03-25-2024, 01:08 PM   #1
BabyM240i
Cruising the Green Hell
BabyM240i's Avatar
Drives: 2023 M240i xDrive
Clunk After Lowering G42
Any thoughts what this rattle/clunk is on what sounds like the front right of my G42? Had a highly recommended shop install my Dähler lowering springs. It's pretty mild, only 1 inch. Springs were Installed on Friday and this clunk/rattle developed shortly before I got home today Monday after driving quite a bit this weekend. Now, it's persistent and happens on all bumps and when I jump on the driver door lol. I pushed and pulled on everything I could and the only thing making any noise at all while under the car seems to be the wheel/axel when rotated but it seems within norms from what I can tell on the internet. Checked bolts up at the strut mount as well and nothing seems loose. Thoughts?
View post on imgur.com
      03-26-2024, 12:46 PM   #2
BabyM240i
BabyM240i's Avatar
Fixed. Loose sway bar end link on the shock body.
Red_sir151.00
TJZ67201874.50
      05-04-2024, 05:48 PM   #3
BabyM240i
BabyM240i's Avatar
Actually, not fixed. Sound returned.
Going to explore if it’s related to this:
SIB 32 01 23
CRACKING/CREAKING NOISE FROM FRONT AXLE/STEERING
SYSTEM
Need to verify which power steering system I have… TKPS or JTEK EPS. I can feel the “noise” in the steering wheel now.
Also going to verify brake bolts etc. All suspension related bolts have been checked and double checked. To include a full alignment.
