10-28-2024, 09:46 PM | #1 |
Rep 25
M2 G87 and oem wheels
Hi,
Do all of the m3/4 G8X series wheels in the 19" front and 20" rear setup fit on the G87 m2? I love the car and was thinking of getting another set of wheels but wanted to go with a forged setup. It looks like the 826m fits. Anyone running a set of 826m's on a g87? Thanks in advance, Matt Last edited by bluekitty; 10-29-2024 at 12:25 AM.. |
10-30-2024, 11:03 AM | #2 |
Rep 4,473
[QUOTE=bluekitty;31588698]Hi,
Do all of the m3/4 G8X series wheels in the 19" front and 20" rear setup fit on the G87 m2? I love the car and was thinking of getting another set of wheels but wanted to go with a forged setup. It looks like the 826m fits. Anyone running a set of 826m's on a g87? Thanks in advance, They are all interchangeable |
10-31-2024, 03:07 PM | #4 |
Rep 3,068
Drives: E36M,E46M,E90M,X5M,i3,M2,i8,M2
Plug and play Or should I say Mount and roll/// lol
G87 M2 25 Frozen Pure Grey Metallic-Lightweight lip,Macht Schnell stud conversion,KW-HAS,MV Forged MVF5,Evolution Racewerks Resonated Midpipe,BMC Filters,Mishimoto Skid Plate F87 M2 Aw-Lightweight lip,Macht Schnell Springs,VF-Engineering/Hex tuning Stage2,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe |
BradMX5527.50 |
11-10-2024, 12:48 AM | #5 |
Rep 25
follow up. Put the 826m wheels on my 2024 m2. the 826m wheels fit exactly the same. Also, the HUF 433MHz TPMS work perfectly. They automatically synch with the car on the first drive. you don't need to reset anything.
11-10-2024, 11:30 AM | #7 |
Rep 54
Would the same hold true for 825m wheels?
I’m thinking of this for my winter setup… OEM 825m wheels on Michelin Pilot Alpine winter tires. Front 285/35/19 Rear 295/30/20 I know 295 rear is fine but is 285 in the front too wide? |
11-10-2024, 12:29 PM | #8 | |
Rep 36
used the factory tires, so cant advise on the tire size change. |
11-14-2024, 02:12 PM | #13 |
Rep 13
Quasi-related question ...
Has anyone created a 20" square setup using 4 stock rear wheels? I'm going with a 19" square setup with 295's all around for summer/track, but thought maybe pick up a used set of stock rims and make a 20" square "all-season" setup with them. |
11-14-2024, 08:25 PM | #15 | |
Rep 65
11-14-2024, 09:13 PM | #16 |
Rep 13
Attachment 3600769Thx. I have the HAS at 'stock' height and am running 15/12mm spacers with the stock wheels (painted BBS gold).
I could go square 285's in which case the rears would obviously stay the same, but I'm wondering if the front 12mm spacer would need to reduce down to 7mm (?) with the 285's. (I am getting insignificant rubbing on the fender liner fins at full lock as is). Or maybe go square 295's but then both spacers would need to change, which isn't a big deal, but I'd need to figure that out. Anyway, yeah they're heavy but used sets are inexpensive and I don't need to squeeze out max performance while running all season tires. Hey M2PDX what tires are you running? Last edited by RobbE30; 11-14-2024 at 09:14 PM.. Reason: question |
