      08-07-2024, 02:34 PM   #1
Rush24/7
Drives: M2
Zunsport oil cooler protection
I currently have the Mishimoto skid plate installed on my car lowered on Eibach Springs. It’s been scraping on my driveway and I noticed it does sit a little lower than OEM, especially the little lip for the rubber air dam. And unfortunately my air dam tore off because of the scraping and I’m not sure a new one will last either.
I was thinking about switching to the zunsport oil cooler grill. Can anybody comment on the clearance versus mishimoto? And do you think it’s sufficient protection for a lowered car driving over speed bumps, inclines, etc?
      08-07-2024, 03:41 PM   #2
NewToM
NewToM's Avatar
Drives: M2 G87 Brooklyn Grey
2024 BMW M2 G87  [9.47]
While my car is not yet lowered, have the HAS kit just awaiting wheels to arrive, I plan on keeping just the zunsport for now as it has been effective so far.
      08-07-2024, 03:41 PM   #3
MG20i
Drives: 2019 Mini Countryman S
I assume the Eibach springs are lower than the HAS springs. How low is your car? The Mishimoto does not stick out that much farther than the plastic stock one. Is your entire front lip scuffed up? Or just the skid plate?
Mike
No more BMWs
A truck and a couple motorcycles
      08-07-2024, 03:45 PM   #4
Rush24/7
Drives: M2
Front is about 17mm lower than stock. The front lip of the car is fine, that doesn’t seem to be scraping. The mishimoto has a tiny lip that the rubber airdam connect to that extends lower than the rest of the plate. Considering the air ram broke off, I’m pretty sure this is the part that is scraping and it’s lower than the OEM stock one.
      08-07-2024, 03:48 PM   #5
wtb1313
Drives: M2
TRE makes something as well with plenty of pictures on the site.
Curious how you feel the pics compare to yours or anyone with first hand knowledge might know.
https://autoid.co/products/bmw-m2-g8...rd-by-tre-2021
      08-07-2024, 03:52 PM   #6
Rush24/7
Drives: M2
Unfortunately I heard this one sits even lower than the mishimoto, so will likely scrape in my case. Looking for a solution that’s as flush with the underbody as possible. Tbh I’m not sure there is one more flush than mishimoto, other than zunsport which prompted this thread.
      08-07-2024, 03:54 PM   #7
Rush24/7
Drives: M2
Let me know if zunsport avoids scraping after lowering please.
NewToM1633.00
      08-07-2024, 06:40 PM   #8
Bret
Drives: 2017 Jaguar F-Type
It looks good, but $520 for a stamped skid plate? Dang.
ednir98918.50
      08-07-2024, 07:19 PM   #9
JABCAT
Professor
JABCAT's Avatar
4250
How high is the bottom of your car off the ground? My other car sits 3.25" from the ground to my splitter & side skirts, and I don't scrape anywhere. I can't imagine your M2 is any lower than that. You may just need to adjust your driving style, take things at angles, etc.
I've had the ZunSport screen on mine for almost 10k mi, stock ride height. I think it's sufficient, but others think the entire undercarriage should be plated in armor.
* I see you posted your front is ~17mm lower than stock. That's not even a full inch, you shouldn't be scraping on anything with that ride height.
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo full Merino interior.
His: '23 M2, Toronto Red Metallic, M highlight interior.
'11 Callaway SC652 Carbon Edition Corvette Z06. Inferno Orange Metallic. 1 of 3.
DSTR1448.50
      08-07-2024, 10:32 PM   #10
Rush24/7
Drives: M2
So from the attached image you can see the mishimoto plate itself sticks maybe 0.5 inches below the bottom if the car. The little lip on the skid plate for the air dam sits even lower, maybe 0.75 inches, and that is the part that is scraping.
I do take my driveway at an angle, but even the sharpest one doesn’t prevent scraping when pulling out. I do agree that the bottom of the car seems too high to scrape anywhere, which is why I thought a flush protector like the zunsport would solve my issue.
      08-08-2024, 09:46 AM   #11
JABCAT
Professor
JABCAT's Avatar
4250
If you're scraping the edge of the air deflector, you're not going to hit your oil cooler with or without a screen. Personally, I wouldn't worry about switching screens.
