11-08-2024, 10:19 AM | #1 |
Rep 30
G87 M2 - track safety devices
Hey Guys,
Does anyone have experience with installing 6-point harnesses on their factory carbon buckets? It seems like they're fit for them, but it's not clear and there isn't much info online. Which rollbar works best with the G87 for harness mounting? Any info would be much appreciated. Thanks! (repost from main thread) |
11-13-2024, 02:19 AM | #3 |
Rep 121
I have the carbon buckets and I believe that carbon cock rest does not allow for a pass through for the 6 points (which should be a crime). If you pass the anti submerging belt in front of it, you're asking to have your nuts removed with any solid impact...
As for half-cages BimmerWorld has one that seems like it allows for tires to be passed through under the cage, which doesn't completely remove the "effective space" in the rear seat. Most other half cages mount into the rear of the trunk which kills trunk space and disables the rear seats to have items in it with bucket seats. EDIT* If you don't care about rear seat space and trunk space CMS has been very popular. You could also just go for a four point harness and not worry about buckets as well.
@DutchBoysRacing
11-13-2024, 10:38 AM | #4 | |
Rep 396
I am working on a concept of a half cage that still allows 3 tires to go through the passenger door area.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, SPL links, Adro wing, IRL exhaust, Verus Splitter, MAD downpipes, Bootmod3; IG:g87_43 |
