      11-16-2024, 02:30 AM   #1
nostromo_
Drives: F20
Question Rookie questions about ECU tuning
Hello all,
I have recently had my car (F20) tuned by a professional (Stage 1 remapping) and I am little concerned about the following:
a) what will happen if BMW service center updates the software? will it erase the remapping?
b) any way to back it up?
c) is using Bimmercode to code basic settings (i.e. auto start-stop) will overwrite the remapping?
Thanks
      11-16-2024, 04:25 AM   #2
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [8.01]
Software updates will erase the remapping.
BMWCCA member Puget Sound Chapter
      11-16-2024, 02:35 PM   #3
M235SDCA
M235SDCA's Avatar
Drives: 16 M235 Vert
Coding modules using Bimmercode or any other application does not impact the ECU map.
If the car is reflashed by the dealer you will need to have the tuner reflash the ECU if you did not use BM3 / MHD to unlock it or flash it yourself.
16 M235 Cabrio - BM3 Stage 2, XHP, ER CP, Wagner DP & Comp IC, MPE, Torqbyte CM5 Water-Meth
18 340i F30 mostly stock
