BMW M2 Forums 2023+ (G87) Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      09-18-2023, 05:02 PM   #1
txmav
Drives: 335i (sold); 2022 X5; 2022 M2
Initial Servicing -- 1,200 Mile Fluid Change
When I was at the dealership, today, having the "replace battery" light taken care of, the SA told me that I need to schedule my initial servicing (the one that is supposed to occur around 1,200 miles). I was shocked, because I have around 200 miles on my car (even though I have had it for around a month).
Does this seem strange to any of you?
Is there a down-side to having it done now?
      09-18-2023, 05:25 PM   #2
Game
Game's Avatar
8130
Drives: G80 LCI, G87 (sold)
Can't have it done at 200 miles or anything close to it. Closest it can be done is likely 1100 miles and even then they may turn you away.
You sure he wanted to do it now or maybe he just wanted you to schedule it (which is still odd since he doesn't know your driving habits)?
      09-18-2023, 05:35 PM   #3
txmav
It is scheduled for two days from now. When they did the diagnostics for my battery, the car told them that I was due for service. When the SA told me this, I questioned him about it. His response was that if the car tells him that the servicing is due, then he can do it.
      09-18-2023, 05:36 PM   #4
M_Power Rob
Drives: '23 M240 and '23 M2
Agreed...my CA told me to call him when I was at 1000 miles to schedule it.
      09-18-2023, 05:37 PM   #5
txmav
I called my sales person to see if this is correct. He checked with others in the service department, and they confirmed that my car is due for the initial servicing.
      09-18-2023, 05:41 PM   #6
txmav
Dealer was telling you to "schedule" it.
Meaning, booking a time for you to drop your car off.
Try to forecast when your car will be at 1,200 miles and schedule it for that day, so you drop it off close to it. It's important to use most of the 1,200 miles because a lot of metal shavings will be collected in the oil/filter, and you'll get that replaced with fresh lubricant. Don't go too soon or more metal shavings will be deposited in your new oil.
You can have the 1,200 miles (or 2,000 km) done very early, it's not recommended. It's not true you'll be "turned away" earlier, but you'll be advised well by the service advisor to not do it too early. 1,100 is not too early.
I was able to get it done before 1,000 Km. I chose to schedule it for 2,000 Km.
Why isn't it recommended? I am trying to understand why I shouldn't do it this early. Do I need to wait longer so the engine is better lubricated with the initial fluids.
      09-18-2023, 06:37 PM   #7
Rx-7ames
Rx-7ames's Avatar
1961
Drives: '23 M2
2023 BMW M2  [7.50]
I just told you why.
True story.
      09-18-2023, 06:42 PM   #8
calbears
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
2018 M3 CS  [10.00]
2011 M3  [9.50]
2017 M2  [9.67]
Nope. Had my M2 done at just over 1000 and M3 CS done at just over 1100. You don't want to go over 2400 miles or so as it will be flagged and cannot be CPO'ed (among other things)
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser
2011 E90 M3 ZCP
Past: E90 328i, F10 535i, F80 M3 (murdered)
      09-23-2023, 11:57 AM   #9
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
My M2 started reminding me the break in service was due in X number of miles at least several hundred miles short of 1200 miles. And as 1200 miles got closer the X number of miles got less and less.
Can't believe the condition based service (CBS) would flag the engine in need of an oil/filter service at just ~200 miles.
Take a pic of the service notice that should appear when you go to use the car.
There is nothing inherently bad about an early break in service. In fact, as is my habit I had the oil/filter service done at ~600 miles. Nothing special about 600 other than it is 1/2 the 1200 break in miles.
With several cars I did an early oil/filter service at ~500 miles. But the flip side is I have done an early oil/filter service at 750 miles, 1200 miles, or even 2K miles. (The 1200/2000 mile oil changes were at the end of "break in".)
(And for engines I rebuilt as I was taught I'd run the engine approx. 30 minutes then drain the oil and refill with fresh oil and replace the filter. A 30 minute run time is about 15 miles of driving -- roughly a car averages 30mph over its lifetime.)
Anyhow, back to my M2: Then at 1204 miles I had the break in service done.
And just Thursday had the oil/filter service done at ~5000 miles. Next service will be at 10K miles.
      09-23-2023, 01:33 PM   #10
txmav
I have a paper that the service advisor handed me saying that my car said that my servicing was due. I will take a picture of it and post it.
As an FYI, I had to postpone my appointment due to a family matter. I haven't rescheduled it, yet, but I am driving my car a lot to put on more miles before the servicing. I really enjoy driving this car.
      09-24-2023, 09:31 AM   #11
RockCrusher
Post a pic if you want. I checked my photos thinking I had taken a pic of the break in service reminder my M2 displayed but I didn't.
Just so it is clear I'm not saying you should not have the car serviced. If the CBS calls for it that's what you should go by.
      11-16-2023, 07:56 AM   #12
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
I just got my 1200 mile service done at 1173 miles…..well, part of the service. They changed the engine oil but apparently there is a shortage of differential fluid and they couldn’t change that. Wondering if I still need to drive gingerly until they tell me to come back in. They said no, but forgive me if I don’t fully trust those guys.
      11-16-2023, 09:41 AM   #13
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
You can drive normally.
Just don’t do burnouts or drifting/tracking.
I figured I would drive normally but haven't hit redline yet due to being under 1200 miles.
      11-16-2023, 09:47 AM   #14
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
Missing out lol
FOMO!!! fo sho.
