BMW M2 Forums 2023+ (G87) Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      12-07-2023, 06:39 PM   #1
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Post Break-In
Probably redundant but I have not been able to find an answer. Is it safe to push the car all out after break in? I just got it done today! I wanted to hit redline and get some heat going.
Thoughts? Had a full diff and oil replacement.
AZG871154.50
      12-07-2023, 06:46 PM   #2
ZPD
ZPD's Avatar
663
Drives: 2022 M850i GC, 2023 G87
Send it
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43
Appreciate 19
      12-07-2023, 06:47 PM   #3
M_Power Rob
Drives: '23 M240 and '23 M2
Let 'er rip...
      12-07-2023, 06:49 PM   #4
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.33]
Originally Posted by ZPD View Post
Send it
Originally Posted by M_Power Rob View Post
Let 'er rip...
GIT ER DUN!
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs:2020 M2C HS Executive, 6 Speed
2017 M3 YMB Executive, 6 Speed, ZCP
Everything else: 2024 Wrangler 4Xe
2024 MK 7.5 GTI
      12-07-2023, 06:51 PM   #5
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
I love the feeedback!!!!
Bumpinjeep6206.50
      12-07-2023, 06:55 PM   #6
IAmSpeed
IAmSpeed's Avatar
Drives: 2023 X4 M40i (G02)
2023 BMW X4 M40i  [10.00]
Yes!!! That's where all the fun start just to be mindful of the traffic, enjoy!!!
2004 Toyota Vios | 2004 BMW X3 | 2007 Chrysler Town and Country | 2007 Ford Escape | 2008 Honda CRV | 2017 Nissan Versa Note | 2017 Toyota RAV4 | 2017 Toyota Yaris iA | 2019 Porsche 911 | 2023 BMW X4 M40i
Geighty72684.00
      12-07-2023, 07:03 PM   #7
Searay55555
Searay55555's Avatar
381
Drives: 2012 335is Convertible
I haven’t been holding back as long as the car is warm. Have fun!
      12-07-2023, 08:29 PM   #8
Trogster
Trogster's Avatar
522
Drive'er like you stole'er.
      12-07-2023, 08:54 PM   #9
Bimmerfun82
Bimmerfun82's Avatar
9397
Drives: iXM60, CLE53AMG, X7 40i
Go for it! I tend to ease into the max effort after break-in service, but you do you
      12-07-2023, 09:08 PM   #10
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Havent floored, but for sure redlined a bit lol.
      12-07-2023, 09:24 PM   #11
MrTiger
MrTiger's Avatar
Drives: Lexus
Drive around for good 15min and warm it up, and then send it!!!
      12-07-2023, 10:11 PM   #12
Searay55555
381
Redline is addicting!!
      12-08-2023, 12:00 AM   #13
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Do you know if there’s any rev limiter taken off or tune for break in? Or is it just fluid replacement + overall health check?
      12-08-2023, 12:07 AM   #14
Searay55555
381
Yes I believe they raised the Redline about 700 rpm to 7200. Someone correct me if I’m wrong.
Geighty72684.00
      12-08-2023, 01:07 AM   #15
AZG87
Drives: G87, 2018 Mustang GT traded in
Get it.
      12-08-2023, 01:14 AM   #16
Tag
this is the way
Tag's Avatar
19988
Drives: N-1 starfighter
They install a flat plane crack, remove the limiter which raises the redline to 9800 RPM and they also give it 121 more hp for good measure!
      12-08-2023, 07:33 AM   #17
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
The owners manual offers no caution regarding the engine/drive train on how you drive the car after break in.
You can drive it as you wish though as others have offered the engine should be fully up to operating temperature -- watch that oil temperature to know when the engine is up to temperature -- before you hit red line.
If you push the car hard after you are finished drive the car some give the engine and drive train time to shed some heat load before you put shut off the engine.
More spirited driving could increase oil consumption. So after you subject the car to more spirited driving check the oil level more often.
      12-08-2023, 07:46 AM   #18
RockCrusher
According to some documentation I was given by my dealer's service department all that is done besides the fluid service is the running in service (RIS) warning/notice is deactivated.
In looking at my car's RIS service invoice I see a multi point inspection was carried out. And a "BMW standard scope service" was done as per factory warranty maintenance.
Also the tech test drove the vehicle. This was mentioned on the invoice. At drop off the car's odometer was at 1204 miles. Upon getting the vehicle back the odometer was at 1207 miles.
      12-08-2023, 08:57 AM   #19
M2GTI
Drives: bmw m2
Time for Ricky Bobby mode. I have my break in service in 2 weeks.
      12-08-2023, 09:44 AM   #20
Searay55555
381
You’re wrong.
That’s happened a time or two. What was the change made?
      12-08-2023, 09:51 AM   #21
Searay55555
381
Change made to what, sorry? At break-in?
The engine oil/filter and diff fluid are changed.
Right, I thought when they did that service they opened up a little more off the usable rpm range. I seem to remember the red mark moving up a little. Maybe I was seeing things.
      12-08-2023, 10:35 AM   #22
KC87ZB
KC87ZB's Avatar
444
Drives: 2023 M2
2023 BMW M2  [10.00]
Yeah, as M2siast says, there are no limits adjusted at the time of the break-in service. Those limits being followed prior to were soft limits of "you should not go above.....". Once you have the 1200 miles AND service done then you have no remaining soft limits, just, like any car, ensure you are up to operating temp.
Note that doing the service early does not eliminate to follow the break-in period limitations.
Of course, your car, do what you want.
2023 M2
2014 Triumph Trophy
Geighty72684.00
