BMW 2 Series Technical Topics (G42) Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      06-21-2024, 09:45 AM   #1
JeffM2PRDallas
JeffM2PRDallas's Avatar
Puerto Rico
51
Drives: BMW M2 F87
M2 N55 Recommended Rod Bearing
I'm looking for some advice on replacing the rod bearings on my M2 N55, which has 29k miles on it. It's seen a lot of track abuse.
Do you have any recommendations for brands? Also, can I stick with the standard size bearing, or should I be looking at other options given the track use?
Than you for your help in advance!
      06-24-2024, 06:11 AM   #2
oldbmwtech
oldbmwtech's Avatar
231
Drives: BMW M240i
Why do you want to replace the rod bearings? Is your engine knocking? Also, without disassembling the engine and taking measurements you won't know what size bearing you will need. Doing this would be a complete engine rebuild.
      06-24-2024, 04:20 PM   #3
chris719
Drives: '08 M Roadster
You'll get better advice on the F87 forums. I'm not sure if I'd be looking at doing rod bearings at 29k unless it's all track time or something. You should find a good shop with experience that can advise you as to what they do on N55s. OEM bearings are color coded and will require you to read the color coding sequence printed on the block I believe.
      06-25-2024, 07:46 AM   #4
BG42
Drives: M240ix
The real answer is b58/s58 swap.
Search this Thread:
Advanced Search
