BMW 2 Series Technical Topics (G42) Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      07-06-2024, 10:21 AM   #1
alxvlkr
alxvlkr's Avatar
Germany
Drives: M240i RWD (G42)
B58TU MHD Log Analysis
Hi everyone,
i recently got my dme unlocked by femto and afterwards flashed a ots mhd map + xhp.
Currently im running MHD Stage 1 (98RON) with 100RON fuel and xhp Stage 2. When doing a wot pull, I often get up to -3 degrees timing correction on a few cylinders.
The car is a 23' M240i G42 with around 20000km and on its first set of spark plugs and ignition coils. I also got a high flow air filter mat and a bigger turbo inlet installed.
Should i change the spark plugs or the coils to get no corrections?
Or what else can i do?
Logs:
https://datazap.me/u/alxvlkr/b58tu-r...?log=0&data=13
(two charts)
https://datazap.me/u/alxvlkr/b58tu-r...0?log=0&data=8
(one chart, made earlier with less parameters)
https://datazap.me/u/alxvlkr/b58tu-r...2?log=0&data=8
Best regards,
Alex
VegasG42597.50
      07-07-2024, 07:12 AM   #2
Rdurty2
Drives: 2022 M240i
It’s not going to be caused by your plugs or coils. 20k is still “new” for those.
Put in some e85 and see if the timing cleans up.
      07-09-2024, 12:54 PM   #3
alxvlkr
alxvlkr's Avatar
Germany
Unfortunately e85 isn't available in germany.
I went for 102RON gas and the corrections are almost completely gone on the 98RON map.
But when trying the 102RON map... ohhh hell no, -4,5 degree and more on all cylinders.
I guess i need to order a eca as well and mix my own ethanol blend.
      07-09-2024, 02:20 PM   #4
Rdurty2
Drives: 2022 M240i
So basically your gas sucks. Either need to keep the octane up, change your tune to use a lower octane, or get a tune that is a bit more mild.
Could always try a different gas station. Also keep in mind that even the stock tune will have some timing corrections.
Search this Thread:
Advanced Search
