09-13-2023, 03:06 PM | #1 |
Supreme Allied Commander
4091
Rep 55,812
Drives: F80 M3
Ohlins Road & Track Coilover Suspension BMW G87 M2 BMS MW00S1
As of this morning Ohlins USA has fitted and confirm Ohlins Road & Track BMS MW00S1 for G87 M2!
DESCRIPTION A more than 40 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises is over. All shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a worldwide 2-year limited warranty on all of our products. GENERAL FEATURES: Patented DFV technology (Dual Flow Valve) Individual height adjustment Rebuildable Corrosion salt spray tested (ISO 9227) 2 year warranty Approx. 10 kgs less weight compared to standard suspension FEATURES FRONT: McPherson strut, upside down Compression and rebound damping with one adjuster Spring preload adjuster Separate length adjustment Approx. 25 mm lower than standard with recommended setup Spring rate 100 N/mm Use with original top mounts FEATURES REAR: Conventional shock absorber Compression and rebound damping with one adjuster Spring preload adjuster Separate length adjustment Approx. 20 mm lower than standard with recommended setup Spring rate 190 N/mm Use with original top mounts PURCHASED PARTS PACKAGE: Coil over kit incl. springs and mounting parts C-Spanner (for spring preload adjustment) Owners manual and mounting instruction Sticker set EDC CANCELLATION KIT: 35020-33 Cancellation kits are not included and need to be ordered separately. FITS THE FOLLOWING VEHICLES BMW G8X M2 M3 M4, YEAR 2020 – Type: G8X Variants: 2WD TUEV certificate in preparation Manufacturer confirmation (SUI) GOCA in preparation (BE) Not for 4WD models (xDrive) |
09-14-2023, 09:31 AM | #4 | |
Rep 1,474
Drives: BMW M2
If anything, the approval part is not at all clear, but that only concerns European customers. Last edited by VIERsr; 09-14-2023 at 09:38 AM.. |
09-14-2023, 09:59 AM | #5 | |
Rep 148
The HAS kits are for people that just want to lower there car, those kits people drop them down low and people are blowing their factory shocks/struts. I feel like once we are talking about Ohlins/AST/Moton etc, even the base kits should be developed for the actual car not just M3/M4 stuff carried over. -GT3M2 |
Charley13542.00 ourlee1521.50 |
09-14-2023, 10:58 AM | #6 |
Joint Chiefs of Staff
27062
Rep 196,132
09-14-2023, 11:09 AM | #7 | |
Rep 1,474
Drives: BMW M2
I am not aware of any coilover kits designed specifically for the M2 and not taken over by the M3/4. |
Brickologic34.50 |
09-14-2023, 11:11 AM | #8 |
Rep 148
09-14-2023, 05:03 PM | #9 | |
4091
Rep 55,812
Drives: F80 M3
Just like on the F8X chassis 50% are perfectly fine with the rates out of the box for their F8x M, but the other 50% want something different. Feel free to reach out to us for custom rates of your particular driving needs. |
GT3M2184.50 |
09-16-2023, 08:36 AM | #10 |
Rep 358
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43 |
09-16-2023, 11:30 PM | #11 |
Car Geek
4255
Rep 3,902
Not as expensive as I’d normally expect Ohlins to be at about CAD$4,300 (USD$3100): https://www.parkautomotorsports.ca/p...ive-bms-mw00s1
deleted_807865_k0a0df9ee6877.50 |
09-17-2023, 02:13 AM | #12 |
Rep 1,474
Drives: BMW M2
It is about the price of a KW V3 and much less than a V4, fair enough.
09-17-2023, 08:39 AM | #13 |
Rep 358
OK I was worried that it was $$$$$ but honestly, I was hoping for $$-$$$
2022 M850i
09-17-2023, 11:45 PM | #14 |
4091
Rep 55,812
Drives: F80 M3
Can't post a price here, but feel free to PM for a discounted price.
https://hpautosport.com/product/ohli...ve-bms-mw00s1/ |
09-18-2023, 10:42 AM | #15 |
Rep 358
so is this system considered a 2-way or a 1-way? It looks like both compression and rebound are adjustable but they are linked together with a single adjusting knob and not independent- Am I understanding this correctly?
09-18-2023, 12:31 PM | #16 |
4091
Rep 55,812
Drives: F80 M3
Ohlins R&T is monotube one way with one knob. However, it does affect compression. it is 90% rebound and 10% compression.
09-23-2024, 03:06 AM | #17 |
4091
Rep 55,812
Drives: F80 M3
Yes, this kit fits the G87. Ohlins confirmed it.
In the latest news. Ohlins will have a TTX-based kit coming real soon! |
lensnaH4.50 |
