      11-15-2024, 10:29 PM   #1
gil
Drives: G87
G87 rear break calipers upgrade options
Does anyone else feel bothered from the mismatch break calipers when you compare the nice front Brembo calipers to the rear Nissan looking calipers? I would like to upgrade to have them look more similar
RMB217.50
      11-15-2024, 10:50 PM   #2
Gbrown
Yes. I can't stand it.
gil4.50
RMB217.50
      11-16-2024, 11:40 AM   #3
JABCAT
Professor
JABCAT's Avatar
4213
Do they stop the car? I'm also usually inside the car when I'm driving it, so don't care what the calipers look like
aerobod4253.00
      11-16-2024, 12:40 PM   #4
BroDoze
Drives: 2025 M2 LCI
This thread is Clown Shoes.
Also, it’s “brake”
///M
Nuhi4.50
BimmerFix1792.00
      11-16-2024, 12:45 PM   #5
aerobod
Car Geek
aerobod's Avatar
https://www.essexparts.com/ap-racing...-m2-g80-m3-epb
....but you probably should do the fronts with a matching set to maintain brake balance:
https://www.essexparts.com/ap-racing...0372mm-g80-g82
      11-16-2024, 01:06 PM   #6
Tag
this is the way
Tag's Avatar
19988
Drives: N-1 starfighter
BMW redesigned the parking brake which use to be a drum style brake housed in the rear rotor. That's why the rear on Gx chassis doesn't have fixed calipers like the front anymore, instead it's a single floating caliper which has the redesigned parking brake integrated into it. As a cost cutting measure, they just painted a floating caliper setup the same color as the front brakes, so they don't show the raw iron and become rusty after a few years instead of developing new fixed calipers to accommodate the new parking brake design.
      11-16-2024, 01:55 PM   #7
MineralGreyMetallic
MineralGreyMetallic's Avatar
1081
Drives: 24 BGM M2 6MT
Were they forced by regulation to change the parking brake?
Seems like a silly trade off.
      11-16-2024, 02:23 PM   #8
techwhiz1
techwhiz1's Avatar
2324
Drives: 2023 i4 M50
Actually the eBrake with the drum, shows,, motor and cables are a nightmare.
2023 i4 M50 - Tanzanite II, Individual Full Tartufo, 20" wheels, all options, PPF, ceramic coating, tinted, lowered (Eibach)
      11-16-2024, 03:18 PM   #9
Tag
this is the way
Tag's Avatar
19988
Don't know, just that they switch to an electronic parking brake (EPS) which doesn't have the brake drum mechanism like the old parking brake. The EPS system electronically clamps the existing rear brake pads instead of relying on another brake in the rotor. For most this isn't an issue aside from aesthetics but for anyone that really drives their car to the limit it's problematic in that the single piston floating caliper does not apply pressure as evenly as static calipers, it's also smaller in size and made of cast iron which means it's more prone to heat soaking quicker than a larger caliper with muultiple pistons and made of aluminum. Lastly you can't just pull pins and replace the pads like you could on the F8x chassis, the entire rear caliper needs to come off. Real PIA if you track your car and need to swap pads. You also need to tell the car to retract the parking brake with ISTA or some other device to remove the caliper.
      11-16-2024, 04:32 PM   #10
beren
beren's Avatar
107
Drives: 1988 Porsche 911, 2024 BMW M2
I guess that is another gripe for that other thread...yeah I wish the car had a manual parking brake.
      11-16-2024, 07:57 PM   #11
JABCAT
Professor
JABCAT's Avatar
4213
You can very easily manually retract the parking brake with a torx bit. You don't need ISTA. 13mm socket (iirc) and 17mm wrench to remove the caliper bolts. Just a couple more steps to remove the rear vs the front calipers to swap pads, but it's still fairly simple.
aerobod4253.00
      11-16-2024, 08:10 PM   #12
aerobod
Car Geek
aerobod's Avatar
Yes, overall less caliper removal effort for the rears than the fronts with just the 2 sliding pin bolts to remove, compared with the 2 radial nuts and 2 pins on the front.
I just bought a Foxwell NT710 maintenance tablet for our Macan that is out of warranty in March, will also buy the BMW module for it. It only takes a few seconds to retract the pads on the Macan with it, as opposed to removing the EPB motor to turn the lead screw with a bit to manually retract the pads.
