BMW M2 Forums 2023+ (G87) Track / Autocross / Dragstrip / Driving Techniques
      03-28-2024, 02:10 PM   #1
anthemavm
anthemavm's Avatar
650
Drives: X3MC
Tire pressure
What tire pressure are people running on the Michelin Ps4.
      03-28-2024, 10:32 PM   #2
ZPD
ZPD's Avatar
663
Drives: 2022 M850i GC, 2023 G87
On the track, autocross, or on regular streets?
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43
      03-28-2024, 11:29 PM   #3
baron95
baron95's Avatar
1866
Drives: BMW G87 M2
Street 30-32 cold.
On track target 34 hot all around, which means starting around 26 give or take.
G87 M2 BSM On Order
      03-29-2024, 07:35 AM   #4
RockCrusher
Best advice I can offer is consult the car's owners manual and find the tire size on the car and take note of other variables: speed and if the car is fitted with the M Package; and use the recommended inflation pressure.
      03-29-2024, 07:38 AM   #5
RockCrusher
Originally Posted by baron95 View Post
Street 30-32 cold.
Going by my owners manual 26psi (cold) is way low even if you aren't exceeding 100mph. Over 100mph...
      03-29-2024, 08:51 AM   #6
anthemavm
anthemavm's Avatar
650
Drives: X3MC
Track
      03-29-2024, 10:19 AM   #7
Ginster6
Drives: G87 with a Stick
came back from sonoma raceway last weekend. I started from my house at 31 cold. and got to the track at 33-34. while waiting for my first session. my instructor told me to add another +2 all around. since it is rain/wet track. session finished at 38psi. I release -1 for the next session and -1 again for the following session after.
the last 3 sessions it was running 36-37 hot thoughout. with temp at avg 115-120F. It felt good
he say most important is look at the sidewall arrow wear and not to go below it.
But all of that depends on your outside weather and condition. it was in the 60F and rain/dry that day.
      03-29-2024, 10:28 AM   #8
Aramis1919
Drives: M240i X-Drive
Tyres on my M240i usually around 35/36 PSI.
      03-30-2024, 11:54 PM   #9
baron95
baron95's Avatar
1866
Drives: BMW G87 M2
Do you do track days at pace? If not, don’t worry about it. If yes you will quickly find out why as your tire pressures will go up by 8-10 PSI in a few laps on PS4S/PZERO. You start low to be at the proper pressure for the majority of the 20-30 min session.
G87 M2 BSM On Order
      03-31-2024, 09:39 AM   #10
RockCrusher
Sure on the track, heck even on the road and even after just a few miles, the tires warm up and tire pressure goes up.
My info is low tire pressure is set when the tires are cold.
From my M2's owners manual:
The tire inflation pressure specifications in the tire inflation pressure table only relate to cold tires or tires at the same temperature as the ambient temperature.
Only check the tire inflation pressure levels when the tires are cold, i.e.:
A distance traveled of max. 1.25 miles/2 km has not been exceeded.
If the vehicle has not moved again for at least two hours after a trip.
For use of the vehicle at speeds greater than 100mph the cold inflation pressures are a few PSI higher.
It is possible that part of the increase in tire pressure you observe is because the tires are starting from a too low a cold pressure (26psi) and the tires are flexing way more because they are under inflated.
With the cold pressure set to the proper pressure for speeds >100mph) the tires would flex less and thus not heat up so much.
      04-01-2024, 12:41 PM   #11
jhstjh
Drives: 2024 M2, 2024 GR Corolla
Just came back from Sonoma Raceway yesterday. I started sessions around 29 and ended at 37, at which point the tires started to lose grip. So 26 sounds reasonable to start if wanting optimal grip later in the session, however the first 2 laps may drive like crap with that low pressure need to take it slow first. I actually prefer to start a bit higher so I can push the car early on and take some slow laps later to cool it down.
