      09-14-2023, 12:03 AM   #1
Stuabroad
Stuabroad's Avatar
22
Drives: 2019 X5 xDrive 40i MSport
Ppf assessment - 4 months on
Bought my 2019 X5 beginning of May with 40k on the clock. Took it to a well-known detailing shop and had a single stage polish, ceramic wrap and PPF in all the usual areas. Vehicle already looked brand new before i got all that work done, it looked even better after. However, 4 months on the PPF is peeling around some of the edges. I've done only local driving in the city and a couple of small < 200km trips to the countryside and even then hardly had any bugs. Vehicle gets babied and washed once a week carefully. We're getting ready for the Canadian winter up here, I’m concerned this is going to get worse. The PPF is looking dirty where it's getting exposed underneath Before I go have a conversation, just wanted to get everyone’s opinion - this PPF shouldn't be doing this after 4 months - right? LOL
*Apologies if the images aren't crystal clear
2011 335 xDrive - retired
2019 X5 xDrive40i MSport
      09-14-2023, 01:01 AM   #2
Prince Thundernight
Prince Thundernight's Avatar
Drives: 2023 BMW M240i XDrive G42
Worrying
2023 G42 ///M 240i xDrive Thundernight Metallic
      09-14-2023, 06:16 AM   #3
bvrider1
Drives: e90 m3 + f80 zcp
my ppf has been on for yrs. The shop you went to did a bad job. There is a 10 yr warranty that is offered for any certified install on ppf too. Might be time to do that but pick another shop.
00SH4WN84.50
      09-14-2023, 08:01 AM   #4
Westside Guy
Westside Guy's Avatar
7258
Drives: 22 Z4 M40i, 21 228i Retired
I have my PPF on for 2 years and have not experienced any peeling like seen in your photos.
After 4 months this definitely should not be happening, take your car back to the shop and insist that they correct the issue!
nunzo868.50
00SH4WN84.50
      09-14-2023, 08:06 AM   #5
Westside Guy
7258
The length of the warranty depends on the brand of PPF installed and whether you have purchased it from an authorized shop. Both Xpel and Stek give you 10 years, Ceramic Pro is 12 years and others can vary.
bvrider1362.00
      09-14-2023, 11:20 AM   #6
Stuabroad
Stuabroad's Avatar
22
Thanks for the feedback. I've dealt with this shop before and never had any bad experiences and the ceramic coating looks to be good.
Looks like they used this stuff:
Premium Shield Elite Nextgen Paint Protection Film
https://premiumshield.com/
Convo this morning:
Shop: That'll just need trimming, that's very typical and why I mention coming back for trims in a month or so. It's just more visible because it's white
Me: How do you mean trimming. Not trying to be difficult, I don't really know much about putting new PPF on a car, but it looks to be worse than just needing a trim. My concern is all the crud from the winter is going to make this worse.
Shop: I trim off a small amount up to where the film is holding. White will always accumulate dirt and stuff on the edges but trimming that extended edge makes it much less
      09-14-2023, 01:35 PM   #7
Stuabroad
Stuabroad's Avatar
22
Apparently Premium Shield Elite is lifetime
      09-14-2023, 01:58 PM   #8
AZHusky
AZhusky
AZHusky's Avatar
Drives: BMW 2024 M340i Alpine White
Convo this morning:
I dunno, that sounds like a cop out answer to me. I've never heard of trimming. Had mine installed on one of my vehicles when it was brand new and the PPF is still going strong no peeling 10 years later.
Trimming to me seems like just a "bad fix" option as now you're going to have even less coverage/protection for the paint and what's to say it doesn't keep peeling up?
      09-14-2023, 03:16 PM   #9
Pheonix
Drives: 2007 Z4 M Coupe 2012 e93 M3
2007 BMW/Z4MC  [0.00]
Man, those are terrible and sorry you have to deal with it.
Trimming is normal when doing PPF but the edges should not lifted and had all kind of crabs built up.
Have both of my M3 and a DD done with partial PPF and never have issues with the edges.
Most likely they have a defective material or the PPF is so bad and the Adhesive never "cured".
Definitely push for a re-do but not sure if I would want the same Film (let alone the same installer).
P111727.00
      09-14-2023, 03:40 PM   #10
chris719
Drives: '08 M Roadster
Yeah this is a shit install or adhesive.
P111727.00
      09-14-2023, 06:50 PM   #11
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
looks like they coulda used more tack solution on the edges. heat also helps to let the slip solution dry out. this is common but not entirely a normal thing. a good install doesn't have this issue
      09-14-2023, 07:22 PM   #12
Westside Guy
7258
Convo this morning:
I have seen several white cars with PPF and none that looks like this. This is not normal trimming, it was a terrible installation.
You should ask them if this will reappear on the edges every time they trim the PPF and at what point will they simply replace the PPF.
P111727.00
      09-14-2023, 09:29 PM   #13
Burrcold
Drives: 2024 M3 Comp xDrive
That's a terrible PPF job. Not even close to any edges at all. Brutal. Hopefully you didn't pay much.
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
P111727.00
      09-14-2023, 09:37 PM   #14
gameson
Drives: 2015 BMW 320i N20
when you guys say warranty, does it refer to the time the PPF can be installed on the car without affecting the original paint? or warranty of any defect workmanship or peeling, etc that they will replace it if within the warranty period?
      09-14-2023, 09:45 PM   #15
bvrider1
peeling, lifting of edges, defects in the material itself.
      09-14-2023, 11:32 PM   #16
gameson
so how many years can PPF stay on the car before it starts sticking on the car paint or hurting the original car paint? does it vary by brands or is there a general guideline?
      09-17-2023, 12:03 PM   #17
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
general rule i'd say is 5-10 years. the low end being if you live in a sun state and leave your car outside overnight/all day.
however, ppf will never ruin your paint when removed properly. sure it will be harder to remove and become brittle as it ages but it should not damage your paint in any phase of its life
      09-17-2023, 12:27 PM   #18
Westside Guy
7258
I have seen PPF that has been on cars for the longest time being removed by the shop I went to without any paint damage.
shimmy232442.50
bvrider1362.00
      09-17-2023, 01:30 PM   #19
P1
P1's Avatar
11727
Drives: 2004 3/4 ton Duramax
That is a horrendous looking and very amateurish PPF install. What on earth did they do in that second picture? Looks like a kindergartener did this during this lunch break.
I'd ask for those areas to be 100% redone. Completely unacceptable.
Burrcold6401.00
00SH4WN84.50
      09-17-2023, 09:23 PM   #20
Housekeeping
Drives: 2013 BMW M5
I’d never ppf a white car, that will happen sooner than later….although 4 months is too soon.
      09-17-2023, 09:35 PM   #21
Davesrb
Davesrb's Avatar
198
Drives: '23 840i, '24 X6 40i, '19 X7
2019 BMW X7  [9.50]
2024 BMW X6 40i  [8.13]
2023 BMW 840i  [10.00]
That is definitely an unacceptable instal, even if they used pre cut PPF. Plus, in some of the pictures it seems to be discolored, like it is turning amber already....
      09-18-2023, 08:04 AM   #22
Westside Guy
7258
We will have to agree to disagree on this. I have seen several white cars with PPF and after a few months they look perfectly fine.
chris7197596.50
00SH4WN84.50
