BMW M2 Forums 2023+ (G87) Issues, Repairs, Warranty, TSB, Recalls
      12-14-2023, 09:21 AM   #1
Axylus
Drives: '23 M2 (waiting)
The “rattling” I am referring to below, is more like a pen-clicking sound.
I am also now experiencing driver-side c-pillar rattling at about 4.5-4.6k miles. Sound is more prominent in sport+ chassis, though there is still some rattling in comfort chassis. In either mode, the sound is intermittent as it does not always occur over bumps or uneven roads, but occurs moreso on the highway at higher speeds. This is bizarre as I did not have any recent work done, but I did have my rear driver window replaced (at around less than 1,000 miles), for which I assume they had to take apart that panel and airbag area.
Update: I believe the sound has become slightly louder and prominent over bumps and uneven roads at lower speeds.
Anybody have a similar situation?
      04-17-2024, 02:24 PM   #2
Zatellia
Drives: 2023 M2 ZB (Manual)
I have something similar except it sounds like its coming from the front windshield... almost like a tiny rock hitting the glass except there are no vehicles or trees around and too cold for bugs. Very random when it happens but sounds like a tiny rock or pen click lol. No clue what it is any when I went in to change my tires out at the dealer, it wouldn't happen while trying to show them.
      08-06-2024, 12:11 AM   #3
nijnella2
nijnella2's Avatar
39
Drives: G87 Zandvoort Blue
Also hearing this faint "click" sound almost sounds like some rubber ish material rubbing against a plastic panel or something. Sounds like it comes from behind but check my rear seats and trunk, still couldn't locate the source of the noise.
      08-19-2024, 11:54 PM   #4
rabbitsmell
Drives: Nd Miata and g87 m2
2024 BMW m2  [10.00]
I have this pen click noise. Some days it's louder than others, but it's coming from my passenger c pillar. I'm going in for my break in service and hopefully they can resolve it for me.
      08-20-2024, 01:47 AM   #5
MrSinister
Drives: BMW G87
I get this sound but it's literally my seat belt rubbing against the pillar. Just haven't taken the time to troubleshoot.
      08-20-2024, 12:04 PM   #6
rabbitsmell
2024 BMW m2  [10.00]
Most certainly not the seatbelts in my case
      08-21-2024, 09:49 PM   #7
-Eidos
@lbb_kev
549
Drives: 2018 BMW M2 (LBB)
I just fixed this by sticking two pieces of a cut up pool noodle in the passenger side access port to the rear shelf located in the roof of the trunk.
Prior to the fix, the sound was so aggravating that I contemplated selling the car.
The original post with the solve is here:
https://www.bimmerpost.com/forums/sh...php?p=29947936
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      08-26-2024, 11:18 AM   #8
azv311
Drives: G87
Take it to the dealer. I had two separate noises and took it to the dealer. Center speaker and a rattling near the cup holders. They asked how long it had been happening, what speeds it happened at, and probably other questions that I cant remember right now. Told them that the speaker happens no matter what I'm playing, and with the bass/ trebble set to 0. The cup holder rattling happened at any speed, when going over any slight bump.
They put felt tape under the center speaker cover and identified that the iDrive controller was rattling, and replaced it, all under warranty.
Hopefully they can easily fix yours too.
      08-31-2024, 06:15 PM   #9
rabbitsmell
2024 BMW m2  [10.00]
Turned out to be a pass rear shock mount. Now I can experience silence
      08-31-2024, 10:17 PM   #10
BroDoze
Drives: 2025 M2 LCI
Glad you found it!
///M
