Be advised-LHD downpipes does not fit RHD vehicle
07-10-2014, 10:30 AM | #1 |
Rep 483
I did blot the downpipes on, but today, after I installed my new water pump, I attempted to lift up the steering rack back in position but then I found the steering column is blocked by the O2 sensor...
So why BMW doesn't make all the downpipes in RHD layout, it won't affect anything on the LHD vehicle and they only gonna need one part number.... All those pain in the ass when I was trying to installed the downpipes are all wasted... So does anybody know is it ok to just seize the O2 sensor hole and let the car run without o2 sensor? |
07-10-2014, 10:44 AM | #2 |
Rep 3,828
Drives: AzuriteBlack 335i E92
Didnt think there was a difference.
I didn't specify RHD or LHD from VRSF and everything went on. Very tight fit and required moving around a lot so it wasn't touching anything, but it went on. You may need to move bits around. |
07-10-2014, 10:48 AM | #3 | |
Rep 483
07-10-2014, 11:18 AM | #4 |
Rep 1,518
Your car won't run without an o2 sensor...
Either get new DPs or get the bung moved Edit: It seems VRSF and AR are the only companies which seem to fit without modification Last edited by idnan; 07-10-2014 at 11:25 AM.. |
07-10-2014, 11:22 AM | #5 | |
Rep 483
07-10-2014, 01:05 PM | #7 |
Rep 386
You can also bend the bung to get clearance. AR guy advised me to do this with 'rhd' ones I have.
Like idnan says it won't run without the o2 sensor. I replaced mine a few months ago due to poor mpg and missfiring |
07-10-2014, 01:09 PM | #8 | |
Rep 483
07-10-2014, 01:31 PM | #9 |
Rep 386
Prob is there is too much variances in these pipes. Mine was only slightly rubbing and a little tweak rotating was enough i could live with it.
Sounds like yours will need taking off. Cant really help other than suggest you trial fit as best you can and work out if the bung needs moved or you can bend it. I would opt for moving it just in case it break trying to bend it! |
07-10-2014, 01:33 PM | #10 | |
Rep 483
going to fabric shop tomorrow for a quote, if it's gonna be too much then I will probably sell this one to other EU countries and get a RHD downpipe |
07-11-2014, 03:16 AM | #13 | |
Rep 483
07-11-2014, 07:12 AM | #15 |
Rep 8,972
