2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Remove small scratches from Black Paintwork
      07-15-2014, 07:21 AM   #1
F11pilot
F11pilot's Avatar
Drives: 2015 320d x-d M Sport Touring
First of all greetings, I'm new to owning a Beemer and new on here. I've just purchased a 2011 F11 520d M Sport in black (sales photos & 1 of my own included). However, it has a kerbed wheel in 2 places that I'm having professionally refurbished and a few scratches here and there which I'm contemplating having a go myself at removing.
You can see in the last 2 photos the worst of these on the tailgate, the top one you can feel bubbling under the paint, but the others are scratches in the clear top coat. Hence the white appearance. Any advice on how to tackle these would be helpful, as I don't want to wreck the paintwork any further and would like to purchase the correct tools and supplies for the job in hand!
Also suggestions in keeping in tip top shape will also be generously received.
Any help will be greatly appreciated and thanks in advance.......
      07-15-2014, 05:33 PM   #2
Monkey Punk
Monkey Punk's Avatar
Drives: 2015 F80 M3
Go to this website....lots of videos and PDF downloads on techniques and equipment needed!
http://www.ammonyc.com
under videos, you will find this one about correcting small dings and chips in black paint:http://www.ammonyc.com/detailing/paint-chip-touch-up/
Last edited by Monkey Punk; 07-15-2014 at 10:09 PM.. Reason: Found a specific link in there
      07-16-2014, 02:43 AM   #3
F11pilot
F11pilot's Avatar
Monkey says......this monkey does!
Thanks for the point in the right direction, I'll use this as a starter for 10 when buying in UK! I'll steer clear from all the polishes/rubbing compounds with black colour enhancers in and invest in some proper tools for the job in hand!!
      07-16-2014, 04:41 AM   #4
Monkey Punk
Drives: 2015 F80 M3
It takes some practice and patience, but once you get the hang of it, it can be easier than thought. Cheers!
Edit: Goes without saying, do it out of direct sunlight to keep paint and clear coat from gumming/clotting up on the job.
      07-17-2014, 08:16 PM   #5
Monkey Punk
Drives: 2015 F80 M3
I am curious....did you have a chance to look at the video of this guy from Ammo NYC? He is definitely OCD, but I think his techniques and advice are great....anyhoo....
      07-18-2014, 02:51 AM   #6
F11pilot
F11pilot's Avatar
Ammo NYC
I did, not sure about attacking the car with a piece of sandpaper stuck to a pencil, as not sure I have enough confidence in my skills without practice! I'm definitely going to have a go at swirl/scratch removal, but going to have to wait until I can afford the proper kit! However, I may take the easier option as I'm having one of the alloys kerb scuff damaged repaired professionally next month so I might just ask for quote to take care of the area in the 2 photos on the tailgate. But I'm purchasing the polishing and washing gear next month after I've been paid and see what results I get done by hand on the polishing.
      07-18-2014, 03:02 AM   #7
Monkey Punk
Drives: 2015 F80 M3
I know your reluctance...I got a piece of a junked car hood from a scrap yard once just to practice on. Besides, yours are vertical, so it is a bit harder to work on versus a horizontal plane. It has been quite a while, so I will have to up my skills. Best of luck....and post some pics if you do get it worked out...let me know the price as well (if you pay to fix it).
      07-18-2014, 06:04 AM   #8
F11pilot
F11pilot's Avatar
Good call on the panel to practice......
I've attacked cars with angle grinders in the past but I'm a little hesitant when your car's worth 20k!
Will do mate, all the best!
      07-18-2014, 06:47 AM   #9
Noggie
Noggie's Avatar
Norway
Drives: E31 850i,i3s
Be careful as bmws factory paint is not very thick, using the right tool for too long and you will go through the paint.
As for the scratches, you will probably not be able to get rid of them completely, a good indication is what the area looks like when wet, that is usually the best you can get it with a proper polish.
The bubbleing usually indicates rust, I would have had that repaired professionally, might get that on the factory warranty actually, dont they have a 5 year rust warranty?
      07-18-2014, 08:01 AM   #10
F11pilot
F11pilot's Avatar
BMW factory paintwork
I had the same thoughts regarding the bubbling, however it looks like it's been caught with something so wouldn't have thought that would be covered under the 5 year warranty!!
Rather disappointing news about the thickness of paint, as I was under the impression that Germans do it better! But I'll make sure I go easy, thanks for the heads up.
      07-18-2014, 01:18 PM   #11
Noggie
Noggie's Avatar
Norway
I would go with a medium pad and medium compound.
Check my writeup here http://f10.5post.com/forums/showthread.php?t=1005257
All modern cars have just a few microns of paint, saves weight and cost.
Used to work in the airline industry, to paint a boeing 737 added 300kg of weight
      07-18-2014, 07:54 PM   #12
Monkey Punk
Drives: 2015 F80 M3
Noggie: I read your attached post. Great stuff! Have you every used a microfiber cutting pad? I have found even with a mild compound, one can get faster results....as long as you know your speeds for the machine well...just curious.
      07-19-2014, 06:56 AM   #13
Noggie
Noggie's Avatar
Norway
I have never used that, no.
I am not a pro, just an amateur when it comes to detailing, I do my own and friends cars.
My pads are medium and fine scholl pads, but I was thinking about trying swissvax medium and fine pads next time.
I have a friend who is, well, up there with the best, Paul Dalton level almost.
He does all the exotic cars in my area.
If you want to see. Here is his facebook page. You will find Porsches, Ferraries, Aston Martins, Morgans, Buggatis ect ect on that page.
https://www.facebook.com/TommysCARSPA
I use his advise when getting products, but since I am a novice I dont want to end up having to repaint a body panel because I went through the paint.
Therefore I stick to medium treatment, which is enough to get rid of swirls, scuffmarks and holograms. And it will take care of most scratches as well.
As I said, the paint is so thin on newer cars that I would not want to use something highly abbrasive without proper guidance.
      07-19-2014, 07:10 PM   #14
Monkey Punk
Drives: 2015 F80 M3
I am as amateur as they come....by no means an expert. As a matter of fact, I bet you'd run circles (no-holo's) around me. Just trying to learn.
      07-20-2014, 06:40 AM   #15
Noggie
Noggie's Avatar
Norway
Its not that hard actually, just takes time.
For us beginners, get a oscillating machine, a rotating machine is much more difficult to use.
You will make holos with it, you can see the tracks from the machine in the sun if not done right.
You can easily overheat the paint damaging it, and it is much easier to go through the paint on edges.
With an oscillating machine you are much safer, its harder to damage the paint, or get holograms or tracks.
I dont use a rotating machine, and I will probably not start using one soon either.
5post
