Intake cam fault codes
07-17-2014, 10:49 PM | #1 |
Rep 76
After changing the VCG on my E86 (N52), it idles roughly on startup until I give it a little gas. I get the following codes via Bavarian Technic: 2A82, 2A99 and 2F45. These are all related to the intake cam timing. The VCG change went pretty easily but I am left to wonder why there is no procedure for re-indexing the valvetronic motor. I suspect that these messages, as well as the rough idle, are the result of that worm gear not reindexing correctly to the gear on the cam driveshaft. Every thread that I read about the procedure says that this motor re-indexes itself after a couple of cycles but I have not had that experience as yet.
Is there any other step i can take before having a shop look at it? I have used a 4mm hex to rotate the worm gear shaft in both directions. It doesn't seem to affect this problem. I get no code for a valvetronic motor failure (is there one?). Is it safe to drive to the shop? TIA |
08-01-2014, 12:09 PM | #2 |
Dustin335i
50
Rep 80
Drives: Mineral Grey M235i M/T
Hey, did you get any resolve here? I'm throwing code 2A82, as well.
Thanks a lot
08-01-2014, 12:41 PM | #3 |
Resident Tamed Racing Driver
298
Rep 4,697
Whoa there, you are getting a little ahead of yourself. 2A82 and 2A99 are both codes relating to the VANOS system, not the valvetronic. More specifically, they indicate a bad VANOS solenoid(common issue). Replace both while you are in there, it is a super easy process.
2F45 is system that checks the key used to the DME. Usually thrown when your battery gets old/weak. Given that you an '08, this seems pretty likely. Get a proper OE battery(they are pretty cheap) and don't forget to code it to the car.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
08-03-2014, 08:38 PM | #5 | |
Dustin335i
50
Rep 80
thanks a lot
08-04-2014, 05:25 AM | #6 | |
298
Rep 4,697
08-06-2014, 11:39 PM | #7 |
Rep 76
I had Kais of Southbay Autohaus put in his GT-1. The intake VANOS solenoid is at fault. Both have been ordered and I should have a chance to install them on Monday. My steering angle code was a result of an alignment (toe adjustment) after I replaced the struts and shocks. Kais is a sharp guy. Very knowledgeable and reasonable.
08-06-2014, 11:50 PM | #8 |
Guest
Rep n/a
Drives:
It can also be the camshaft position sensors intake or exhaust, not just the solenoids as it was in my case, I kept getting codes they finally went away with the sensors after replacing 1 solenoid and using it to troubleshoot.
Furthermore if you car has newer DME software (been updated at the dealer post 2010 I believe) BMW introduced a cleaning profile that runs on startup that helps keep the solenoids in check, there is a TSB on this. |
10-22-2014, 11:40 AM | #10 |
Rep 5
Hello dears,
Please i'm very desperate right now i love my bmw so much (325i e93) since 5 months ago i started getting the fault code 2A82 intake vanos. First of all i've tried cleaning the solenoid the error went off but after 20 min of driving it returns. I swapped the intake solenoid with the exhaust (logicaly the 2a87 error should pop up if the solenoid need a replace but sadly it didn't ) I'm still getting the 2a82 error . Today i replaced the intake soleniod with a new one i drove my car but sadly i still getting the error . My mechanic told maybe the new solenoid need adaptation ! But i don't think it will solve the problem , he told me if the problem persist he will change the vanos ! That's crazy my car has 100000 km in it and i've already spent 500$ without getting any concrete results. i would appreciate any help thank you |
10-22-2014, 10:58 PM | #12 |
Rep 76
You aren't in Lebanon. Parts can get to be stunningly expensive in other parts of the world. I once sold a used set of Kumho race tires to a fellow in Seattle who was putting together a small container of Porsche parts to be shipped to a vintage racer in Germany. Go figure.
