New Gloss Black Grilles
07-19-2014, 12:53 PM | #1 |
Rep 447
Fitted today, really pleased with the overall look, just need to get the bonnet/bumper shut lines a bit better... Cheers Spugnut/Dan for supplying.
07-19-2014, 01:02 PM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
Looks stunning - what a great colour your car is! Shut lines look pretty normal to me. Good luck with adjusting them!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
07-19-2014, 01:29 PM | #3 |
Rep 447
Cheers Phil, face on they are ok, but from the top I would just like them a little bit closer if you know what I mean, the black grilles just seem to show up the gap a bit more than the chrome...
Spent a couple of hours making some shims just to raise it up, pic is with 2mm but I made 4mm first and the bonnet would not close... so going to make some at 3mm... From no shims to the 2mm made a massive difference to the look, so think the 3's will be spot on... |
07-19-2014, 02:20 PM | #5 |
Rep 447
Cheers MXD, problem is now I think I need to brighten up the lower grilles so they match up - never ends once you start!!!
And the rear diffuser will also need to be sorted.... do I just spray the original or go with a performance one in gloss.... |
07-19-2014, 04:30 PM | #6 |
Rep 512
Thats an absolutely stunning colour, please give me your car :P
my shut lines are the same, been bugging me for ages even adjusting bumper didn't help me
My Previous Cars
206 1.4, Sport Ka, 206 Gti, focus 1.8, Vectra 1.9 CDTi, Corsa 1.8 Sri, 206 Gti 180, Impreza Blobeye Sti Widetrack, Clio 172 Cup Track Car, E92 335D, Impreza Hatch STI, Evo IX FQ360MR, E92 M3 Competition |
07-19-2014, 04:41 PM | #7 | |
Rep 447
If you look at the two pics, first is how it was and always bugged me and when I fitted the black ones it seemed to open up more and looked nasty, the second pic is with 3mm shims under the left and right torx bolts and 4mm under the two centre bolts at top of bumper.. I just cut and drilled some plastic packers in the end, has made a massive difference to how it looks... |
07-19-2014, 04:45 PM | #8 | |
Rep 512
you should, its an amazing colour! ill give that a try tomorrow thanks for that, so the 4 torx bits above the grills?
My Previous Cars
07-19-2014, 04:51 PM | #9 |
Rep 512
My Previous Cars
07-19-2014, 04:53 PM | #10 |
Rep 447
Yes mate, them four.. I used plastic window fitting packers cut up but if you have some m5/m6 washers I would do 2 on left and right and try 3 on the middle one's.. see how it looks.. I would also mark and take pics of where the bolts sit in relation to the hole cut outs on the bumper as I had a bit of trouble getting the faces right between bumper and bonnet if you know what I mean... would have saved a bit of time.....
07-19-2014, 04:57 PM | #11 |
Rep 447
Looking at that pic, I would go 3mm left 4mm both centres and only 1mm on the right, see how that sits - you are not far off with what you have done tho...
07-19-2014, 05:03 PM | #12 |
Rep 512
Thanks mate ill give that ago tomorrow
My Previous Cars
07-19-2014, 06:19 PM | #13 |
Rep 149
Performance diffuser in gloss black would look awesome! I have the same on mine (albeit my car is silver!).
07-19-2014, 06:31 PM | #14 |
Rep 512
its a very important change, i just painted mine sparkling graphite and it makes the back end look soo much better
My Previous Cars
