07-20-2014, 07:08 PM | #1 |
Rep 825
New foglights
Upgraded the stock foglights to 2400 lumen LED 'bulbs'. Install was simple plug and play and I only used a suction cup and a knife to pop the housing out and trim the backing. No iDrive errors but I don't know if they flicker on startup yet, as I need to find a big reflective surface to test. Bought them from kbcarstuff (aka xenondepot) with a 15% coupon.
Down for Maintenance
07-23-2014, 08:11 AM | #5 |
Rep 825
Thanks everybody. This weekend I plan on getting some night shots so show the cover and spread. Night shots with a camera phone suck so I'm going to dig out my DSLR. I also have some LED reverse lights installed from Putco, but they do trigger the "Warning, backup lights out" message.
07-23-2014, 08:44 AM | #6 |
Rep 11,852
Drives: MY24 G01 AW Msport
why not get new oem foglights that are LED
07-28-2014, 08:01 AM | #7 |
Rep 825
Actually never looked in to that since I got these on sale. Did not get a chance to take night photos, had some other things come up this weekend.
My guess is like other retrofits, you would have to do some coding of some sort to get the LED retrofit housings to work properly. These were 100% plug and play.
07-28-2014, 08:41 AM | #8 |
Rep 11,852
or it might be a simple plug n play upgrade since its standard feature on both 28i and 35i.
unless the foglight housing is different in size or in shape since it has new front design |
07-28-2014, 02:30 PM | #9 |
Rep 2
Brilliant mod! Been thinking about doing exactly the same thing as I am not a fan of the yellowish tone of the fog lights.
Need to get this done ASAP. Thanks for the inspiration, good job. |
07-28-2014, 06:57 PM | #10 | |
Rep 825
Won't be disappointed! Light output really shines
07-29-2014, 02:01 PM | #12 | |
Rep 560
I will let you know what they say! |
08-01-2014, 03:25 PM | #13 |
Owner
Rep 566
Drives: G05 30d M-Sport
I'm quite interested too, the yellow fogs are quite ugly really, and I don't like having to put a big resistor in front of LEDs to prevent the warning, it's a bit silly
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
08-06-2014, 06:45 AM | #14 |
Rep 560
My BMW dealer has told me that the fog lights from the LCI will not fit. I assume that this is true, but I would like to see diagrams of both to know if a retro-fit is possible with a couple of mods!
08-18-2014, 11:14 AM | #15 | |
Rep 825
09-05-2014, 10:12 PM | #16 | |
Rep 273
09-08-2014, 12:23 PM | #17 |
Rep 825
Night shots with just the DRL's and then the fog lights on. As I post this, I just realized I can turn the DRLs (Angel eyes) off in the i-Drive
09-09-2014, 11:27 AM | #20 | |
Rep 825
The forum coding guru's would have to weigh in on that I guess.
01-02-2020, 09:47 AM | #21 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.26] |
Bump I just did same mod... huge improvement. Only thing to add is I had to code off voltage monitoring using Carly to avoid the fog error malfunction.
01-02-2020, 01:21 PM | #22 |
Rep 191
I have thought about it. But not sure I want to take apart my headlights and risk messing something up. But Im sure you could retrofit another actual projector in there.
