Developed WG Rattle and 30ff in same day **Fixed**
07-29-2014, 09:33 AM | #1 |
Rep 60
Lately I've noticed my car doesn't pull as hard as it use to.
A few days after getting my D-CAN cable in and trying to set everything up to code my car had a half engine light come on. As soon as I got home I noticed the rattling. Last edited by force_feed; 08-05-2014 at 08:23 AM.. |
07-29-2014, 08:27 PM | #2 |
Rep 60
OK I pulled the engine cover off and found the two vacuum lines by the oil filter busted.
I replaced those and I'm still getting the half engine light (30ff) and no power. |
08-04-2014, 03:54 PM | #3 |
Rep 60
I changed the vacuum lines next to the oil filter due to them being cracked. But it didn't fix the 30ff code.
I did a boost leak test on the car today and to my surprise, everything was sealed up. So I did as advised on N54tech and was going to check the vacuum on top of each canister. Found a broken nipple on one of them I eliminated the canisters and everything is working great. The car even feels faster than it did before, so that's a plus. I'm not sure if I'm going to put the canisters back in. If I do I'm going to mod mine with brass barbed fittings on top and bottom. |
08-04-2014, 04:34 PM | #4 | |
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Interesting, thanks for sharing what you found. So there's a vacuum canister delete mod or did i misread your post?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
08-04-2014, 04:37 PM | #5 |
Rep 3,158
Thanks for sharing the solution with us ff. I'll bet this will be useful for someone around here soon enough.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
08-04-2014, 05:20 PM | #7 |
Rep 609
Force Feed,
Anyway you can post pictures of what exactly you checked? I installed a chargepipe and DCI and am now getting a 30FF boost leak. I took it by a shop and they said the install looks good so they have no idea and I shouldn't be getting that code. I did blow the OEM chargepipe off my car after only a few HARD pulls with the JB4 (blew hard enough that the bolted on support part even completely sheared off and the CClip portion was obliterated), so I'm thinking maybe this blow off caused a potential issue with my vacuum lines.. |
08-04-2014, 05:26 PM | #8 |
Rep 1,652
The only real concern if you didn't do the install yourself is, did the shop transfer the O-ring from the old CP to the new one? Could be it was overlooked and not put on. It would look fine install wise from the outside but it could cause a minor boost leak.
If not then yeah check everything Force checked. All the vacuum lines.
08-04-2014, 09:47 PM | #9 | |
Rep 609
I need a picture to see what he checked. MPower checked my vacuum lines to my diverter valves and all looked good. The ones that go to the canisters, I have absolutely no idea what the OP is talking about so I really need a pic ha |
08-05-2014, 07:56 AM | #10 |
Rep 718
Does anyone know of a good way to pressure test these lines?
Mine look fine visually, but I would like to pressure test them in case there are any leaks that are not visible. I am getting a waste gate rattle and would like to make sure it isn't just these lines before I bring it to the dealer. If I disconnect the ones near the oil filter, should they each hold pressure and if not what would I need to do to get them to hold pressure? I was thinking I could rig up a way to use a bicycle pump with a gauge to see if they are holding pressure.
08-05-2014, 08:11 AM | #11 |
Rep 60
There isn't a vacuum canister delete mod, at least I couldn't find any info on it from my search of the forums and Google.
The first thing I did was inspect and replace the vacuum lines behind the oil filter. The canister was broke and I wanted to get my car back on the road so I removed both of them completely. These are the vacuum canisters This was the broken nipple Last edited by force_feed; 08-05-2014 at 08:25 AM.. |
08-05-2014, 08:14 AM | #12 | |
Rep 2,136
http://www.e90post.com/forums/showthread.php?t=870905 I would put the vacuum canisters back on. Without them, it will take longer for the wastegate to completely close and accentuate the turbo lag.
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch Last edited by Gizm0; 08-05-2014 at 08:19 AM.. |
08-05-2014, 08:20 AM | #13 | |
Rep 60
I plan on modding the canisters with barb fittings and putting them back into the car. But sense removing them I've had no problems what so ever, and honestly the car pulls harder than it was before the 30ff code. Maybe it was due to the cracked vacuum lines behind the oil filter, I'm not entirely sure. |
08-05-2014, 09:18 AM | #16 | |
Rep 60
In my opinion I don't think you would be able to pressurize the entire intake manifold bc you will constantly loose pressure due to valves being open. But I could be wrong! |
08-05-2014, 11:05 AM | #17 |
Rep 718
That's what I was thinking, but I had read about someone blowing into the lines to find a leak. Maybe they were just able to hear air coming out of where it was leaking.
08-05-2014, 12:29 PM | #18 |
Rep 609
I had a shop check the vacuum lines that connect to the OEM diverter valves and they looked fine so I think my issue might be by the canister or by the oil filter if this is indeed a vacuum line problem. |
08-05-2014, 12:44 PM | #19 |
Rep 41
Drives: 2007 335i E90
I have the same rattle when I'm idle and rev it.
So the cause was a broken nipple on the canister? That's it? |
08-05-2014, 01:20 PM | #20 | |
Rep 60
By eliminating the canister I eliminated the vacuum leak. I connect the hose that went to the top of the canister to the line that went in the bottom of the canister. I did that for both canisters. Last edited by force_feed; 08-05-2014 at 01:26 PM.. |
08-05-2014, 01:26 PM | #21 |
Rep 60
