Indy recommends against coolant flush
07-29-2014, 09:34 PM | #1 |
Rep 41
Did a number of maintenance services recently on my 2010 328xi that just hit 60K. One of the services on the list was coolant flush. A very reputable indy in Seattle area recommended against it. Their opinion is that changing coolant at this time/mileage may provoke water pump failure. They're saying I should expect water pump to break around 80K and at that time I'll be able to replace it along with thermostat and coolant. What do you guys think? I certainly don't want to provoke a water pump failure but at the same time I think the 80K on average for the last production year of e90 seems very low estimate. I was expecting around 150K. Should I still go ahead and replace coolant?
07-29-2014, 09:45 PM | #3 |
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Interesting theory. 80k does seem low. Depends how much you drive on average though.
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
07-29-2014, 09:47 PM | #4 |
Rep 41
I think they had previous experience like this including one car where the pump failed to start right after coolant flush. The car likely was another E90 but I doubt it was 2010. They told me something about speed deviation but I'm not really sure I absorbed it right.
07-29-2014, 10:40 PM | #5 | |
Rep 1,754
However, I can't imagine why coolant flush/fill would affect the pump at all. |
07-29-2014, 11:10 PM | #6 |
Rep 2,189
Sounds like the good old "dont replace the ATF in an old AT with old fluid".
There could be some wisdom in all of this but it wouldnt stop me from replacing the fluid in any case. If it was on its last leg it was on its last leg either way. I'm going to continue to move forward with the maintenance with my car myths be damned. |
07-29-2014, 11:36 PM | #7 |
Rep 41
07-29-2014, 11:37 PM | #8 |
Rep 128
Stupid theory, even at 95k my pump never failed. Only reason I replaced it was my thermostat stayed stuck open and I figured since I was in that area I would replace the pump also.
07-30-2014, 03:54 AM | #10 |
Where'd my VTEC go?
481
Rep 6,067
My water pump failed at around 85k. Coolant flush wont cause it to fail as the failure is due to electronics like Efthreeoh said. But with impending failure, might as well hold out until the pump fails to change out the coolant. Or proactively change the pump along with the new fluid.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
07-30-2014, 10:35 AM | #12 |
Rep 2,446
How long do you intend to keep the car?
His argumentation is not bad. I would wait 2 more years at least and then possibly do the job. In the mean time check BMW codes regularly, looking for anything related to the coolant pump speed. Some people here reported that codes were raised many months in advance. Last edited by Saintor; 07-30-2014 at 10:41 AM.. |
07-30-2014, 10:37 AM | #13 |
Rep 313
My pump went out at 90k.
But I think no matter what you do, it's still going to go out anyway. I think you should just wait for your pump to go out. BMW cannot seem to get it right, since they are on their 3rd revision on this already, I think. |
07-30-2014, 10:46 AM | #14 |
Rep 596
That's BS... I haven't replaced my TS/WP just yet... at 117K miles on the clock right now. Still going strong. It's gone through two coolant flushes for its lifespan thus far. 07 E90 N54.
2007 BMW 335i, 2014 Audi A4, 2016 Acura MDX
Join us on Facebook: E90Post - Houston Houston BMW DIY Services |
07-30-2014, 10:50 AM | #15 |
Rep 10,120
That's misinformation, I replaced my coolant on my old N52 at 75k miles and drove the car to 94k before training it in. Car had no issues with the water pump after the flush and fill. Water pump failures are electrical and have nothing to do with the coolant; unless of course the coolant is seriously dirty and has contaminants in it. But then again this is exactly why you are doing a coolant flush in the first place.
07-30-2014, 11:16 AM | #16 |
DIE ANTWOORD
68
Rep 640
On my bimmers the waterpump issues always happened at pretty exactly 148.000 km which would equal 90k miles.
In my opinion it's worth to think about it what the service man suggests. |
07-30-2014, 01:19 PM | #17 |
Rep 13,122
The main reason to change it is to prevent corrosion.
The main reason to change it is to prevent corrosion and get the contaminants
out. Which would hasten cooling system failure. My INdy is saying 4 years or mileage. Last edited by ctuna; 07-30-2014 at 08:09 PM.. |
07-30-2014, 03:53 PM | #18 |
M-GAM3
240
Rep 1,264
+1 BS
Car Enthusiast.
07-30-2014, 03:58 PM | #20 |
Rep 7,215
I don't get the hoopla over a waterpump that lasts 100k miles. yeah, they're expensive. but water pumps are wear items, they don't last forever - most cars these days probably last around 100k on a pump. on older BMWs it was more like 50k.
also, if you beat on your car the pump will run more and therefore wear faster. it's not surprising that the turbo cars might go through pumps a bit faster than N/A cars. Last edited by hassmaschine; 07-30-2014 at 04:12 PM.. |
07-30-2014, 05:08 PM | #21 |
Rep 3,393
I can understand the theory behind people not changing trans fluid, but this one doesn't make sense.
I'd change it out. Coolant + distilled water isn't much money. That is of course if you're not doing the coolant flush yourself, then I suppose it could be more costly. -Don |
07-30-2014, 05:11 PM | #22 | |
Rep 2,293
I think it was probably a coincidence the shop had a water pump failure after replacing the fluid or they somehow messed it up when flushing the coolant and the pump failed after. I can even go as far as saying one of their mechanics did not tight something right and it was leaking which may have let to a pump failure , he probably blame the water pump. I can understand the shop recommending not to changing the fluid if the car was new and low mileage |
