new wheels...pretty chuffed
08-01-2014, 12:13 PM | #5 |
Rep 3,200
Drives: E92 325i MSport Coupe
Very nice. Genuine BBS or reps?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-02-2014, 12:57 AM | #14 |
Rep 515
They look amazing, although I am a bit biased because I used to have a set on my GTi Edition 30
Pain in the A to clean, well I thought so until I had MV2's on the Z4 Coupe and now MV4's |
08-02-2014, 03:18 AM | #15 |
Rep 3,200
So are you running spacers at the mo? If not you're going to have some difficulty resolving the rubbing issues as there's very little lip on the arches to roll...
08-02-2014, 03:26 AM | #16 |
Rep 2,796
Lovely looking wheel and in a couloir that really works. Superb end result, BBS CH's are as you can see a personal favourite of mine having had a genuine set for 5 or so years.
And yep they are a pain to clean so well worth when fresh'n'new thoroughly cleaning and sealing with a decent sea lent which makes life a lot easier in the future to keep on top of |
08-02-2014, 03:58 AM | #17 |
Rep 523
cheers guys,im not one for cleaning wheels ,just use turtle wax alloy cleaner,spray on leave for 3 mins then jetwash off,,,always does the trick lol,i have had ultralites on my skylines (pic below)that were similar in design (although with a big dish),love the design of them
and no,no spacers,it happened once,only driven 3 miles since fitting them,maybe i heard something else,will see if it rubs today |
08-02-2014, 04:47 AM | #19 |
Rep 515
I don't use any products anymore for cleaning wheels after my old z4 wheels corroded around the wheel nuts.
I just use a bucket of warm water and a microfiber. Then seal the wheels afterwards and then they are nice and easy to clean next time |
08-02-2014, 05:44 AM | #22 | |
Rep 860
Car is looking great As per messages there is no way the wheels should be rubbing on the back with an et38 bud. You can run as low as et30 (As a lot of members are running on here on our previous 359 style wheels) with a 265/30/19 on a pre LCI coupe and not have any issues. As I said, have a check to see if any of your inner plastic arch guards have came lose an dropped down a little. Can be the only thing I can think of. Have a check and let me know Chris. |
