XDRIVE E90 Problems After wheel change
08-02-2014, 02:43 PM | #1 |
Rep 5
ok guys so I got my hands on some f10 wheels they are 18x8 Et 30 but i used two different size tires for front and back
i did 225/40/18 on the front and 245/40/18 on the back but im getting problems with the dsc, when i hit certain bumps it vibrates and then the dsc light comes on, is this because Im staggered, it didnt do it before with the oem wheels.... Any feedback is appreciated.. Last edited by Gustavz973; 08-02-2014 at 02:50 PM.. |
08-02-2014, 04:24 PM | #2 |
Master Bates
80
Rep 495
Yea man. Its the stagger, or better yet the roll out. What will determine your staggered compatibility is the roll out calculation of your tires. They need to exact/as close as possible else your front and rear axles will turn at a minimally different rate which is likely to cause trouble with your tranny.
I've done your calculations for you on what you own and the measurements on the tire itself and you have a 2.4% difference in tire size which is significant. You can do more measurements here: http://tire-size-conversion.com/tire-size-calculator/ This will help you determine what size tires to use so that you can get the same/similar roll out for both front and rear.
CURRENT: 2020 G20 M340 xDrive — Carbahn Tune
RETIRED: 2011 E90 335i xDrive — Cobb AP3, PE Exhaust, Alpina TCU Flash, VRSF Charge Pipe 2017 Estoril Blue X1 M Sport — JB4 |
08-02-2014, 04:45 PM | #3 |
Rep 2,835
That tool will get you in the ballpark, but you need specifics from the tire manufacturer to be exact.
But yes, your stagger is way off.... The rolling circumference of a.... 225/40/18 is 1945mm 245/40/18 is 1990mm So your rear tires are trying to travel 50mm more than your front tires each revolution. Since they are basically locked together by the transfer case you can see why you have a problem. |
08-02-2014, 05:00 PM | #4 |
Rep 1,834
Drives: 08 E90 335xi TiAg
Run squared or you'll destroy your tcase and/or differential(s)!
Don't drive it anymore until you match front/rear tires or get your rear tires under 1% rolling diameter difference. I run 235/40/18 F and 265/35/18 rear. Since you have squared rims you should stick to squared tires. |
08-02-2014, 05:13 PM | #6 |
Rep 13,122
Go to the xi sub forum
I think its possible to run staggered widths but not diameters. Though I wouldn't do it . |
08-02-2014, 11:52 PM | #9 |
Rep 116
Staggered width is not an issue but the front to rear rolling diameters must be within a certain tolerance, on 4-Matic it's 1/10th of an inch front to rear not sure what it is on xDrive. The major risk is wearing on your transfer case or differentials because of increased heat due to the improper ratios. If it is causing issues with DSC rarely I doubt it's an issue, but over EVERY bump and turn it is probably worth changing them.
Since you did the same sidewall ratio for front and rear on different widths I can already tell you the sizing is wrong. Generally you want (once again speaking on my 4-Matic and general tire knowledge) a difference of 40mm front to rear (245/285, 255/295) and a sidewall aspect ratio difference of 5 (225/40 and 265/35). But as everyone said above your best bet is to go calculate out your rolling diameters as they can vary per tire brand too. Best of luck |
08-03-2014, 12:19 AM | #10 | |||
Rep 2,823
No 225/40/18 is the correct size for e90's. Quote:
215/40/18 front 245/35/18 rear 225/40/18 front 255/35/18 rear 225/40/18 front 265/35/18 rear 235/40/18 front 265/35/18 rear 235/40/18 front 275/35/18 rear
08-03-2014, 12:30 AM | #11 |
Rep 1,038
Any references to "ruining your differential" while running staggered front-rear setup in xi car are nonsensical. Modern BMW xi AWD system does not have center differential, so obviously it can't get ruined.
BMW xi is an electronically controlled "wet clutch pack" design. It is true that putting staggered wheels on this system (outside of acceptable tolerances) can lead to unjustified activation of the clutch and premature wear or overheating of the system. However, as far as I know, this system can be programmed for each specific front-rear wheel diameter difference, if you really want a staggered setup on an xi car. Albeit I don't remember ever seeing it done in USA. |
08-03-2014, 07:17 AM | #12 | |
Rep 5,370
08-03-2014, 09:06 AM | #13 |
Rep 1,464
Drives: 2009 BMW 335xi
Actually just the pure physics of the system will not allow for the a front tire that is smaller than the rear without some problems "programming" or not. With a slightly smaller diameter front tire (< 1%) you will get surging and some drive ability issues/annoyances. With a drastically smaller diameter front tire (> 1%) you will definitely have major problems and error lights. Basically you have to keep the front tires the same or larger diameter within 1%. Wheel and tire width does not have any effect on the system.
08-03-2014, 09:26 AM | #14 | |
Rep 2,835
08-03-2014, 09:36 AM | #15 |
Rep 633
Oem 18" wheels on my '08 335xi came with 225/40-18 front and 255/35-18 rear.
08-03-2014, 10:31 AM | #16 |
Rep 1,464
08-03-2014, 10:54 AM | #17 |
Mr. Monaco
155
Rep 4,197
Yikes so much poor information here. The xi can handle staggered widths, as others have said the key is to be within that 1% rolling diameter. Stay away from mixing and matching brands
08-03-2014, 11:06 AM | #18 | |
Rep 633
08-03-2014, 11:30 AM | #19 | |
Rep 1,834
Irresponsible post, dude. You should take I down since you clearly don't know what you're talking about. Reread your post. Are you on salvia? |
08-03-2014, 12:48 PM | #20 |
Rep 10,120
Please ignore my post on the fronts I made a mistake as someone else pointed out.
Optimal tire size for 18s on a xi staggered is (as stated in the manual and the setup I have) Front 225/40/18 Rear 255/35/18 |
08-03-2014, 05:12 PM | #21 |
Rep 535
08-03-2014, 08:54 PM | #22 | |
Rep 1,038
That applies to any other "mechanical genius" here who managed to "discover" a center differential in BMW xi AWD. |
