What Should I Be Doing for My E92?
08-03-2014, 08:11 PM | #1 |
Rep 2,132
I own a 2010 e92 335i 6MT.
I have 26,000 miles and am the original owner having done all scheduled maintenance. My only mod is a Dinan stage 2 tune and otherwise stock. What preventative/needed things should I be doing to keep it running well? |
08-03-2014, 08:30 PM | #3 |
Rep 357
Continue oil changes. At 45k do a walnut shell blasting and tranny fluid change along with the 45k service plugs etc. Also I'd recomend getting a clutch delay valve from bms. Made a worlds difference for me.
08-03-2014, 08:33 PM | #4 |
Q(*.*)-D Q-(^.~Q)
214
Rep 5,378
Drives: like an old person.
Member since '09. Can't tell if serious question...
08-03-2014, 09:04 PM | #6 |
Rep 2,132
08-03-2014, 09:05 PM | #7 |
Rep 2,132
08-03-2014, 09:23 PM | #8 |
bOrN To DiE
413
Rep 1,738
08-03-2014, 09:43 PM | #9 |
Q(*.*)-D Q-(^.~Q)
214
Rep 5,378
All good man. Just keep up what you're doing and you'll be fine. I follow all the maintenance plan and at 173K miles, my car is running solid.
08-03-2014, 11:23 PM | #10 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
A friend of a friend of mine has an 07 335i and has put 50k on it in the last 4 years and has had zero problems. Just oil changes and standard maintenance. The 335i is a reliable car if you maintain and treat it well... just like most other cars.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
08-04-2014, 11:10 AM | #11 | |
Rep 2,132
This is less of a financial decision and more of just a question of how to keep the car running well. Even if I had to sell for scrap, I'd be fine. I own the car with clear title. Stop spamming my thread now unless you have other advice. I appreciate what you've said, but I get your position now. |
08-04-2014, 11:11 AM | #12 | |
Rep 2,132
Has your windshield fluid pump given you any problems? That's the only thing I need to fix at this point. |
08-04-2014, 11:50 AM | #13 |
BimmerPost Supporting Vendor
24411
Rep 191,282
Walnut blasting in another 5 000 miles.
08-04-2014, 07:29 PM | #16 | |
bOrN To DiE
413
Rep 1,738
08-04-2014, 08:40 PM | #17 |
Rep 1,192
Drives: 2011 335i MT
Frequent oil changes are the best way to take care of the engine. I always do oil changes much sooner than the manufacturer calls for. I always ask the mechanic to inspect the engine for any loose hoses, belts, etc. Preventative maintenance.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
08-04-2014, 08:56 PM | #18 |
Q(*.*)-D Q-(^.~Q)
214
Rep 5,378
Nope.
