N52 e85/meth ?
08-10-2014, 05:51 AM | #1 |
Rep 319
N52 e85/meth ?
Has anyone attempted to get a tune for meth injection or e85 for the n52? Was wondering if any at least small gains are possible doing this? Have seen naturally aspirated m cars do it so thought n52 would have something but nothing showed up in the search
08-10-2014, 04:31 PM | #2 |
just another bmw douche bag
195
Rep 3,640
you'd need a lot of compression to make use of e85. e85 is less efficient at making power than gasoline, but it has a very high octane value. Turbo cars compensate for this with the ability to run more boost, but with an NA car, you need to increase compression and timing to offset the loss in power.
So unless you are planning on rebuilding your motor, you are going to have a hard time making any more power than stock with e85. |
08-10-2014, 04:35 PM | #3 | |
Rep 319
08-10-2014, 05:46 PM | #4 |
Rep 9,004
08-11-2014, 02:44 PM | #8 |
Rep 7,215
it's actually 10.7:1 (don't know where I'd read 12.5:1). but yeah, maybe or maybe not enough to take advantage of something like E85. you'd need to be able to adjust the tune and you'd have to upgrade the entire fuel system.
08-11-2014, 02:46 PM | #9 |
Rep 319
Yea I was checking in on e46fanatics and see how they were on this same topic and really only possible if you were able to upgrade the injectors and fuel pump but those things aren't available for the n52
08-11-2014, 03:33 PM | #10 |
Rep 9,004
08-11-2014, 04:26 PM | #12 |
Rep 7,215
what do you mean? there's no reason you couldn't upgrade the injectors and fuel pump. there's nothing that special about the N52, it's not DI and doesn't have a HPFP. not that I believe it would be worth the cost.
08-11-2014, 04:32 PM | #13 |
Rep 319
I haven't seen anyone talk about putting bigger injectors in their n52, been on some big sites like **********s and turner and no bigger injectors available for the n52. I know bigger injectors and fuel pump is a good decent mod. Had mustang injectors in my old e36 and that was really pleasant
08-12-2014, 07:28 AM | #14 |
Rep 7,215
injectors are pretty standard parts, you'd just need to find one with the same body size that flowed more. You probably haven't seen anyone do it because there's no benefit without a seriously modified motor. there's no point in upgrading the injectors by themselves, plus it wouldn't work without retuning the computer anyway.
I don't know how big the N52 injectors are but BMW typically sizes them with lots of headroom available that I doubt anyone is pushing a relatively stock N52 past. |
08-12-2014, 07:39 AM | #15 | |
Rep 319
08-12-2014, 08:26 AM | #16 |
Rep 7,215
I'm going to guess no. newer motors use short body injectors, also the size is probably smaller than the stock N52 injector anyway.
seriously, there's no reason to upgrade your N52 injectors without some serious mods that would require them (like a turbo or supercharger). I don't think you would need them even if you had a cam upgrade. |
08-12-2014, 10:33 AM | #17 |
Rep 790
thought the n52 was 10.7.1 and n51 10.1. ???
2010 335i M sport
2008 328i 2006 325i 1995 Z28 6spd - 377rwhp rip |
08-15-2014, 10:49 PM | #18 |
Rep 4,040
Drives: 130i coupé ;)
Last time i talked about this. there was no enthusiasm.
Meth kits from snowperfromance or 335i water reservoir can be used as long as you make the trigger either on /off or maf based next you need a tune or you will get just octane boost/cold air effect
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
08-18-2014, 11:48 PM | #19 |
Rep 1,951
There are two reasons to inject a meth-water mixture - methanol will increase octane rating, however this isn't a particularly significant effect. The mixture, primarily due to the water, also has the effect of cooling the airflow into the cylinder. This is useful as it increases density of the air charge, decreases pressure, and prevents any hot spots from prematurely detonating the a/f charge causing knocking or worse.
In a naturally aspirated engine, none of these effects are particularly useful. You don't get pre-detonation because you're not running the fuel close to its detonation pressure. You don't get hotspots because you're not running a higher-than-design intake temperature or combustion temperature. tl;dr meth/water injection lets you crank up the compression for the same fuel. But that's not a variable you control on an NA engine, so fuck it.
08-19-2014, 09:25 AM | #20 | |
Rep 3,856
