08-29-2014, 12:44 PM | #1 |
Rep 323
i3 LED Headlights
I read that the i3 has LED Headlights instead of Xenon. Are they the adaptive LED headlights like what's on the 3 and 5 when you get LED? Do they turn and move around, or is it a different system?
08-29-2014, 01:04 PM | #2 |
Rep 59
I can't tell you exactly, but I noticed they are not like cornering lights, so they don't turn when you turn the steering wheel.
They are a different colour to xenon, though. I personally really like it - sort of a purplish dark blue. |
08-30-2014, 12:49 AM | #3 | |
Rep 172
There are problems with this approach. Among those problems are the following: 1. The high beams have a completely different color profile (warmer, more old school) from the low beams, so it almost looks like a mistake when you turn on your high beams. 2. The high beams (to this observer's unscientific eye) provide less brightness than the low beams. Which seems totally counterproductive. And less safe. |
08-30-2014, 10:52 AM | #4 |
Rep 1,061
There are other halogen bulbs you can put into the high beams to closer approximate the color temperature of the LED's. I'd be careful of using a higher wattage bulb, though. Not sure if there's room enough for xenons and their ballast, but, in theory, you could get more light with lower power. Hassle is, turning them on/off all of the time isn't very good for their long-term survival, not counting the start and warm-up delay.
08-30-2014, 11:19 AM | #5 |
Rep 323
Interesting, I wonder if this is a cost cutting measure? Seems like putting in halogen bulbs would waste more electricity than having LED high beams.
Are the LED low beams in a projector, or is it like the newer BMW where the "angel eyes" are the headlights? |
08-30-2014, 02:54 PM | #6 |
Rep 1,061
The low beams have a very distinctive beam, and aren't just a simple reflector.
Being a car primarily designed for use in a city, not sure how much you'd actually be using high beams, which may have played into their thoughts on what to use there. |
08-31-2014, 12:23 PM | #8 |
Rep 165
Laser headlights (optional).
1975 2002 Inka/blk, 1975 2002 Red/blk (lthr) (owned '77-'79), 1976 2002 blue/tan (lthr) (owned '80-'81), 1979 M1 Orange/blk (owned '82-'84), 1980 320iS Silver/blk, 1984 323i Drk blue/cream(European) E30, 1996 M3 White/blk E36, 1998 328i Silver/blk E46, 2002 330i Silver/blk E46, 2006 330i Silver/blk E90, 2008 335iSilver/blk E90, 2012 135i SGM/blk E82 (all with manual gearboxes), 2014 i3 rex Arravani Grey/terra
08-31-2014, 01:23 PM | #9 |
Rep 1,646
08-31-2014, 03:26 PM | #10 |
Rep 1,646
Answered my own question. Per BMW website for i8:
"All lighting elements are completely in LED and low-beam and high-beam are widely spaced." |
08-31-2014, 04:54 PM | #11 |
Rep 106
If led lights are energetic more Eficiente than halogen why this strange mixture for the i3? Definitely it's not very hi tech as an electric car from bmw should be?
08-31-2014, 05:31 PM | #12 |
Rep 1,061
An LED headlight bulb is in the order of 10x more expensive than the H11 halogen. Considering how often you can use your high beams in a city, it may be a fair compromise. You can retrofit LED bulbs, but with their attached heatsinks and you'd probably need a load resister to keep the monitoring circuit from saying the bulb is bad, it could be tough, since the load resistor typically needs to be mounted on metal to act as a heat sink for it, and there isn't really much of any nearby.
09-02-2014, 07:48 AM | #13 |
Rep 87
i8's have LED low and high beams and LED cornering lights as well. No laser headlights for the USDM (yet, I've heard some good things for next year but time will tell on this one)
product genius at BMW of Mt. Laurel in New Jersey
96 Volvo 850 Turbo 120k |
09-02-2014, 06:50 PM | #14 |
Rep 715
how can the i3 not include cornering lights?
BMW's been a pioneer in this technology for at least a decade.
E92 335i|Jet Black|Black Dakota|Alu|Step/paddles|ZPP|ZSP|6FL|Navi|Heated Seats|CA
09-03-2014, 05:58 AM | #16 |
Rep 1,646
....that...and cost cutting.
It can't be easy to make a city car from aluminium and carbon fibre, and sell it at a relatively low price whilst making some profit. So, I imagine BMW cut every non essential item they could, and then made it so customers would specify a lot of options - all at a healthy margin. I don't blame them. The carbon fibre and aluminium are a HUGE part of why it drives so well, which is why I bought one |
09-21-2014, 08:49 AM | #18 |
Rep 2,218
Do you guys remember when HID's were just coming out? At first a car had normal low-beam HID's, and the high-beam lights were still halogen. Then as time progressed, bi-xenon HID's came out where the HID was both the high and low beam. On my e46, however, the "flash to pass" and "DRL's" (disabled on my car) are still a halogen bulb.
Perhaps the second generation LED's will be bi-level, in other words, have the ability to adjust (mechanically) and be used for both low and high beam. I would probably still choose LED over Xenon but LED is so much cheaper to construct, I would be haggling about the up charge for them.
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17- - 2015 CPO i01 BEV Laurel Grey Tera World, '17- - 2015 i01 REx Laurel Grey Tera World, '15-'17 - 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15 |
09-21-2014, 10:59 AM | #19 |
Rep 1,646
It's just a question of cost saving, not technology. The i8 has every single light on it, in LED. Unless you opt for laser main beams.
09-25-2014, 12:46 PM | #20 |
Rep 87
For smaller LEDs this is true. For vehicle lighting applications requiring such high output LEDs, this is not the case at all
09-28-2014, 01:29 PM | #21 | |
Rep 2,218
I apologize for that somewhat incorrect statement, I didn't realize they had the same mechanics as an HID to keep from blinding oncoming traffic. Glad they do now that I've driven one for a few days, the distance is AMAZING.
09-29-2014, 03:51 PM | #22 | |
Rep 1,646
The laser headlight option still has LED for low beam, and laser for high beam. |
