Cold Idle
09-06-2014, 10:14 AM | #1 |
Rep 28
Cold Idle
Hi guys I have a cold idling issue. The car seems to misfire when left to idle. It's fine when you put some revs on. I'll post the inpa codes below but they're in german for some reason the N53 doesn't get English language codes .
I bought the car used with 3 months warranty, and now its just out of warranty it's decided to not play ball. There's no engine management light on for some reason but there's plenty of codes! Any ideas will be greatly appreciated! EDIT: I did a rough idle test in inpa and cylinder 4 was consistently going into the red, may shed a bit of light Code:
current kilometer reading: 96476 km ___________________________________________________________ $error locationNr: 11013 $error locationtext: 0x2B05 Stickoxidsensor, Heizung 57042B0504002205FF272B5802037B002B5C02037C002F1B01037B00 Error: 1(4) No.: 11013 0x2B05 Stickoxidsensor, Heizung frequency: 255 error type: 4 (4118 ) Leitungsunterbrechung readines Flag: (16 ) Testbedingungen erfüllt error status: (32 ) Fehler momentan nicht vorhanden, nicht OBD-entprellt MIL - Status: (48) Fehler verursacht kein Aufleuchten der Warnlampe (MIL) P-Code: P2205 NOx-Sensor Heizungssteuerkreis (Bank 1, Sensor 1) - Fehlfunktion oder Leitungsunterbrechung F_LZ: 39 ambient text / entry at 96472 km(n.) 88800 km(2.) 88768 km(1.) Luftdurchsatz OBD 2.56 g/s 5.12 g/s 5.12 g/s Motor Status PL PL PL Spannung Kl.87 Rohwert 2.40 V 2.42 V 2.40 V Status NOx-Sensor 0.00 - 0.00 - 0.00 - ___________________________________________________________ $error locationNr: 11015 $error locationtext: 0x2B07 Stickoxidsensor, elektrisch 57042B070800122C0C262EFD020580002EFD060381002F1908038000 Error: 2(4) No.: 11015 0x2B07 Stickoxidsensor, elektrisch frequency: 12 error type: 8 (4474 ) Kurzschluss readines Flag: (16 ) Testbedingungen erfüllt error status: (32 ) Fehler momentan nicht vorhanden, nicht OBD-entprellt MIL - Status: (48) Fehler verursacht kein Aufleuchten der Warnlampe (MIL) P-Code: P122C NOx-Sensor Schaltkreis (Bank 1) - Kurzschluss F_LZ: 38 ambient text / entry at 96456 km(n.) 96232 km(2.) 96232 km(1.) Luftdurchsatz OBD 20.48 g/s 15.36 g/s 5.12 g/s Motor Status PL PL PUC Spannung Kl.87 Rohwert 2.50 V 2.52 V 2.50 V Status NOx-Sensor 0.00 - 0.00 - 0.00 - ___________________________________________________________ $error locationNr: 11014 $error locationtext: 0x2B06 Stickoxidsensor, Lambda linear 57042B060800121F0C262EFD020580002EFD060381002F1908038000 Error: 3(4) No.: 11014 0x2B06 Stickoxidsensor, Lambda linear frequency: 12 error type: 8 (4474 ) Kurzschluss readines Flag: (16 ) Testbedingungen erfüllt error status: (32 ) Fehler momentan nicht vorhanden, nicht OBD-entprellt MIL - Status: (48) Fehler verursacht kein Aufleuchten der Warnlampe (MIL) P-Code: P121F NOx-Sensor linearer Lambdasignalschaltkreis (Bank 1) - Kurzschluss F_LZ: 38 ambient text / entry at 96456 km(n.) 96232 km(2.) 96232 km(1.) Luftdurchsatz OBD 20.48 g/s 15.36 g/s 5.12 g/s Motor Status PL PL PUC Spannung Kl.87 Rohwert 2.50 V 2.52 V 2.50 V Status NOx-Sensor 0.00 - 0.00 - 0.00 - ___________________________________________________________ $error locationNr: 11003 $error locationtext: 0x2AFB Stickoxidsensor, Lambda binär 57042AFB0800122F0C262EFD020580002EFD060381002F1908038000 Error: 4(4) No.: 11003 0x2AFB Stickoxidsensor, Lambda binär frequency: 12 error type: 8 (4474 ) Kurzschluss readines Flag: (16 ) Testbedingungen erfüllt error status: (32 ) Fehler momentan nicht vorhanden, nicht OBD-entprellt MIL - Status: (48) Fehler verursacht kein Aufleuchten der Warnlampe (MIL) P-Code: P122F NOx-Sensor binärer Lambdasignalschaltkreis (Bank 1) - Kurzschluss F_LZ: 38 ambient text / entry at 96456 km(n.) 96232 km(2.) 96232 km(1.) Luftdurchsatz OBD 20.48 g/s 15.36 g/s 5.12 g/s Motor Status PL PL PUC Spannung Kl.87 Rohwert 2.50 V 2.52 V 2.50 V Status NOx-Sensor 0.00 - 0.00 - 0.00 - ___________________________________________________________ |
05-15-2015, 05:36 AM | #5 |
Rep 28
Just for some closure to people with these codes (I've had a fair few PM's)
In the end it was down to the injectors. My dealer replaced all 6 at good cost and also wanted to do the knox sensor while they where at it. Becuase I wanted the 2 year warrenty I was obliged to have it done. If you want to save a bit of money then I'd recomend a specialist to replace your injectors. The knox sensor is there to alter fueling to suit emissions. I paid 400GBP for the knox sensor alone without fitting so its well worth a punt. If theres still an issue then you can always replace it after. |
