Preventative maintenance in '08 328i......worth it?
09-15-2014, 08:02 PM | #1 |
Rep 262
I have a '08 328i that just rolled 90k. I bought it CPO'd in 2010 with ~26k on it. Havent had a single issue yet, and the car feels solid as a rock. Handles great, engine feels strong, 6MT is smooth, etc... The only things ive replaced have been tires/pads/rotors. I did have the dealer flush my brake fluid about 6 months ago.
The car is paid for, and i am *hoping* to drive it for quite a while longer. I would like to go to 150k if i can, as long as it doesnt turn into a money pit. Ive read a few recent threads on the things most likely to crap out (water pump/gaskets), and i was wondering if there was any benefit to replacing them preemptively. I dont want to replace things too early if they still have life, but if there is a well known life of a particular part, it may be best to fix it before it breaks. Also, since the majority of costs are labor (gaskets), would it be too tough to do that myself? My BIL is a mechanic (not a BMW mechanic), so we have the tools and some know-how, but is the job over our heads? I dont want to tear the car apart and not be able to get it back together Let me know what you think. |
09-15-2014, 08:20 PM | #3 |
Rep 1,995
Replacing a water pump before it goes is a waste a money. You never know when they will go. You could replace if and the new one would go 20k later.
Just get AAA if you are worried about getting stuck somewhere. I tjlhink there 200 mile tow is 79 dollars a year. |
09-15-2014, 08:23 PM | #4 | |
Rep 262
09-15-2014, 08:39 PM | #5 |
Rep 1,995
09-15-2014, 09:01 PM | #6 |
Rep 13,128
Google Mike Miller BMW for a maintenance schedule.
Change all the lifetime fluids and plugs . Be prepared to change your water pump and VCG and oil filter housing gasket. There are a bunch of DIY's in the DIY sub forum here and on ytube. If you are not a Gorilla and prepared to put some time in to study the DIY's you can do a lot of this stuff yourself. Be sure to use a good torque wrench. |
09-15-2014, 09:59 PM | #7 | |
Rep 262
Seems like 100k is the drop off point where proper maintenance really matters. If i can do most of the work myself, its probably worth the investment. If most work requires special tools/knowledge, im probably better off selling it. |
09-15-2014, 10:13 PM | #8 | |
Rep 1,995
09-16-2014, 12:04 AM | #9 |
Rep 13,128
If you do half of what Mike Miller says
it will be more than twice as much as BMW does under the free program and more like what any car should have done as a minimum. That means the stratigic replacement of fluids and filters every 30 to 60k oil ever 7500 or once a year. Spark plugs at 90k. All you need in the beyond common tools is a good torque wrench and it would also be good to have something like BMWhat or coding setup that does diagnostics. (Both of which are real cheap)The big problem with maintenance is having space to work on it and getting easy access by getting it up the air. I see a lot of older BMW's on the road that look well kept. Mike practices aircraft maintenance you can't pull over in a airplane but I bet he is never stuck on the side of the road. At between 125k and 150k I would be thinking about a new radiator and Water Pump if it hasn't failed yet though. Last edited by ctuna; 09-16-2014 at 12:10 AM.. |
09-16-2014, 06:24 AM | #10 |
Rep 335
The maintenance steps already suggested are great to keep your car rolling pass your 150K miles goal. If you like your car and perform routine maintenance it should last a long time (I sold my prior BMW ~4yrs ago with 200K miles and it is still running). The typical maintenance required on a 328 cost a lot less than buying a new car.
09-16-2014, 07:23 AM | #11 | |
Rep 1,995
Not sure what made bmw people not trust bmw or oil specs backed by engineers in many different fields but I follow bmw makntence plan and my car is yet to explode at 91k. In fact you are better off just to follow bmw maintenance and take the money you save from not doing mike miller crap and put it towards parts that actually break. |
09-16-2014, 07:34 AM | #12 |
Rep 2,869
I am literally in the same position as you.
I have a '08 328i sedan. 84k. 6MT. Also bought it CPO'ed... had about 38k on it. I am going through the exact some thoughts in my head... Do I want to keep this car long term OR trade it in spring 2015 on a e92 M3 possibly. So far, only thing I've really done maintenance wise is brakes, which I did myself. I have my DSC module replaced under CPO along with a new thermostat and coolant (no water pump though) around 60k. However, my valve cover gasket and oil filter housing gasket are both starting to show signs of them going bad, and most likely need to be replaced in the next 3-6 months. Also, with the NA engines, 100k service calls for spark plugs. I love my car... but my thoughts are... if I want to keep it, I'll need to invest AT LEAST $3,000-$4,000 into it with the gaskets, and inevitably when the water pump dies, along with spark plugs. OR, do I not do any of that, hope my car makes it to spring, and then trade it in on something else? I feel like if I did invest $ into my car, these NA inline-6 engines will run for a long time... and I would feel pretty comfortable keeping my car to 150k... Or do I buy a "money-pit" M3 and call it a day?
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
09-16-2014, 08:00 AM | #13 | |
Rep 1,995
09-16-2014, 08:25 AM | #14 | |
Rep 2,869
I'd estimate 1200-1500 for valve cover gasket 400-600 oil filter housing gasket 200-400 spark plugs 1200-1500 water pump (obviously that is including laber, and my "guesses" on what the dealer would charge based upon other peoples experiences)
09-16-2014, 08:46 AM | #15 | |
Rep 1,995
09-16-2014, 11:36 AM | #16 |
Rep 8
New To BMW
New guy here. I am completely new to BMW's and never had anything but American cars.
Picked up a steal of a 07 328xi this weekend for my wife. It has 70k miles on it. I'm hearing that the AWD can be a problem after 100k. What I would really like to know is what I need to be watching out for? What maintanence schedule should I get on and what fluids should I get changed now to get started on a good schedule and make sure i'm good to go? Any general or specific info would be much appreciated. THANKS!! |
09-16-2014, 11:42 AM | #17 | |
Rep 1,995
Personally I think at this point you should let transmission fluid ride out until it breaks but that is just me. It's what I am doing.. |
09-16-2014, 01:53 PM | #18 | |
Rep 335
09-16-2014, 01:58 PM | #19 |
Rep 13,128
Well you could spend 4000 to 5000 on maintenance
Well you could spend 4000 to 5000 on maintenance.
If you can DIY or have a good Indy it will be much less. Or you could buy a new car and have it depreciate 10k when you drive it off the lot and 5 to 3k every year after that. There are many sub forums here and one of them is on AWD. |
09-16-2014, 02:15 PM | #20 | |
Rep 1,995
No proof that changes all the fluids before what bmw says will prevent anything |
09-16-2014, 02:52 PM | #21 |
Rep 8
I am most interested in preventative maintenance. I do know the oil has been changed but that's about the extent of what I know
I can see through the diagnostics in the dash some future dates/milage for a few things but not things like transmission or transfer cases and the like. And can the computer have been reset and not be accurate now? I know only a little about the cars history. But at the price we just couldn't pass it up. But everyone I talk to stresses the maintenance schedule and maintenance history. And I don't have anything telling me what should be done and when other than the computer. I hope to not be taking it to a dealer. I have friends that have given me the number to a reputable Indy. Maybe I should just take it to them and see what they say? |
09-16-2014, 03:43 PM | #22 |
Rep 18,808
I'm just going to throw in here. I've followed BMW's maintenance schedule for the E90, that means the CBS items (17,000 mile OCIs) and 100,000 mile driveline fluid and plug changes. I just turned 260,000 miles this month. These cars do not need the level of preventative maintenance of an airplane (I think Ctuna came up with that gem - LOL). They just don't. The common problems the E90 has (WP, T-stat, OFH gasket, VCG, etc.) are not preventable by a higher rate of preventative maintenance. Stuff breaks because of time, environment, mileage, abuse, and build/assembly quality of the parts and vehicle. I'm even on the original radiator (but with all new hoses).
You can follow Miller's schedule and waste a butt-load of money, or do what BMW recommends and get an easy 150 - 200K out of your car. |
