11-05-2014, 01:58 PM | #1 |
Rep 87
HID or blue/white colored foglights
i was wondering if its possible to change the foglight oem color with a headlight matching color. The yellow foglights with bluish white headlights looks weird
thank u |
11-09-2014, 01:16 PM | #4 |
Rep 87
11-10-2014, 08:05 PM | #6 |
Rep 1,134
I just installed some GP thunder 7500K. its a very easy install. just need to remove the wheel housing cover, twist the bulb, and it comes out
the bulb you need is an H8 |
11-10-2014, 08:12 PM | #7 |
Rep 674
Tell us more about the GP thunder 7500, are the more white, more blue, do they make a similar bulb, halogen for those of us with Halogens. Are happy with them and I take it no warning lights.
11-10-2014, 08:16 PM | #8 |
Rep 1,961
Its an H8 bulb. I don't think HIDs will work. I tried putting them in my F02 and the wiring couldn't give the ballasts enough power to ignite them. And trying to use a relay harness failed because it only uses 1 light as a turn on lead, so the other light always showed as out in the OBC. Ended up putting LUX H8 LEDs in the 750 and using those same bulbs in the 335GT when it gets here.
