Help with brake pads. correct ones to buy and size discs?
12-18-2014, 04:41 AM | #2 |
Rep 891
320D will be 300mm front discs
get these: http://www.ebay.co.uk/itm/Front-Fero...item565d2b72a9 they wont come with sensors(do have the cut out for them though), but sensors are either cheap from ebay, or just remove them by soldering the 2 wires together. |
12-18-2014, 04:49 AM | #3 | |
Rep 2,399
I was thinking maybe Pagid or Textar whatever they are called. might have to go ECP as i need them for this weekend Do you have much knowledge on the sensor? can they be re used etc? |
12-18-2014, 04:50 AM | #4 |
Rep 3,312
Use realoem or similar to find the size of the disc or even call the dealer parts to confirm.
As for sensor as its made contact best to replace it but they aren't expensive and you only need one for the front. |
12-18-2014, 05:10 AM | #5 | |
Rep 2,399
Best thing maybe is to just measure the disc i guess with wheel off. |
12-18-2014, 05:44 AM | #6 |
Rep 891
Those Ferodo Premier are better than the oem spec pads from Textar or Pagid.
unfortunately once the sensor has been triggered they have to be replaced, you can re use them if you change the pads before they wear out, but once its down to the wear sensor, the sensor gets "used" and you need to replace. (or just bypass them by soldering the wires together, although this means you need to look at the pads to judge wear) |
12-18-2014, 06:00 AM | #7 | |
Rep 2,399
p.s. its only a 320d so wont need the best of the best pads |
12-18-2014, 09:03 AM | #9 | |
Rep 189
I'm not saying Ferodo, Pagid etc don't make a suitable pad, but yes you really do need a quality performance item. |
12-18-2014, 03:08 PM | #10 |
Rep 422
Measure them mate. I ordered some off eBay awhile back and they didnt fit even though seller said they would. Luckily the disks had more life in than I thought and just changed pads.
12-18-2014, 03:11 PM | #11 |
Rep 3,312
12-18-2014, 03:20 PM | #12 | |
Rep 422
Unless someone is driving it like they stole it alot then theres no need for a performance pad. Everyday normal driving then the brands he mentioned are fine. |
12-19-2014, 03:00 AM | #13 |
Rep 891
those premiers are a "step down" from Ferodo's fast road pads (the famed DS2500's) they are designed for normal road cars
12-23-2014, 04:49 AM | #15 |
Rep 181
EBC = CRINGE.
I had a horrendous experience with EBC pads on a friends car where they were fitted correctly bedded in properly and them promptly cracked apart under normal use. He fitted them about a month before a hill climb event and had to rush and buy another set of pads (this time mintex 1144's) a week before the event!! I always without fail spend cash on brakes, Delphi disks are good along with Brembo and they don't cost a fortune. Also when it comes to pads Mintex 1144s or Ferodo DS2500s are probably the best all round pads you can lay your hands on. |
12-23-2014, 09:44 AM | #16 | |
Rep 891
1144's / 2500's can be a wee bit extreme for daily driving, the Ferodo Premier is a fantastic road pad. I've never had a problem with discs, i always just purchase the cheapest disc possible, its just a lump of metal at the end of the day. (same goes for our track car, that's currently running some Jinyu(or something) discs with DS2500 pads) |
12-23-2014, 11:42 AM | #18 | |
Rep 5,623
If anyones interestes let me know, i run the E90post group buy for EBC products. |
