E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > rear shocker replacement 335d time and parts
Reply
      12-29-2014, 05:31 PM   #1
Ajs_435d
Ajs_435d's Avatar
355
Drives: 435d m sport m performance
Had a good look under car today noticed drivers side rear shocker has misting on it, wondering what's the best brand etc to replace it with? Obviously on all 335d it's m sport suspension don't know if that will make a difference? Wondering how long it will take to replace too.
I did one on a fabia vrs years ago took my top hours, 3 bolts up top, compress leg and bolt on bottom arm.
Cheers
      12-29-2014, 06:36 PM   #2
JP.Williams
JP.Williams's Avatar
United Kingdom
16
Drives: E93 335i
One bolt at the bottom one bolt at the top!
always worth changing both sides at onces if you are doing like for like change. ie keeping standard m sport shocks.
you have to remove or move the rear side boot linings that takes the longest.
worth changing upper and lower shock mounts. you have to remove them so worth changing.
LeMans Blue E93 335i | Koni Yellow | H&R Springs | 9/10J Style 92s | MHD | BMS DCI | VRSF Downpipes | ML Inlets | ML Stage 2 Hybrid Turbos | Retrofit CIC
      12-29-2014, 09:06 PM   #3
daveleach
Drives: 335d
Done mine both sides in under an hour. Was pleasantly surprised how easy it was
      12-30-2014, 02:53 AM   #4
Ajs_435d
Ajs_435d's Avatar
355
Thanks, what do we recommend as replacements second hand bmw or new units?
Cheers
      12-30-2014, 05:29 AM   #5
Sheepy
Sheepy's Avatar
181
Drives: F82 M4 Competition
I got the sachs m sport shocks for my 330d from Eurocarparts, I believe they are what BMW use without the badge & the hefty price tag. If they are the same part no on the 335 my receipt shows the ECP part no 635110580, they are not handed on the rear so you will require 2. Think they worked out at around £100 for the pair, I did all 4 as one of my fronts was leaking & total bill came to £245.
      12-30-2014, 07:16 AM   #6
Ajs_435d
Ajs_435d's Avatar
355
Thanks mate spot on.
Cheers
Reply
e90post
