E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > 335i n54 no power till 4500rpm... help?
Reply
      12-31-2014, 02:35 PM   #1
redstu21
Drives: 335is n54
Pretty new here, but not a newbe when it comes to bmws or n54s.
Like I said having trouble with my car no low down power till dead on 4500rpm. Then bang will spin wheels even at 80
No fault codes.
I'm fbo. Run 105 race fuel and 6at.
So far I have checked charge pipe.
Divert valves for week /broken springs.
Renewed vacuum hoses from pump to boost valves.
Anything else would be helpful, kinda going mad...
      12-31-2014, 02:54 PM   #2
parksjm7
parksjm7's Avatar
81
Drives: E92 07 335i
2007 BMW 335i  [0.00]
2002 Honda  [0.00]
If you have an older car, boost solenoids come to mind. Changed mine to the updated part number not too long ago which solved my issue - similar as yours
      12-31-2014, 10:48 PM   #3
umut335i
umut335i's Avatar
United Kingdom
28
Drives: 335i Convertible 2007
I had the same issue. Thought I had checked the blow off valve, though when I checked it the second time it had popped off. Got my mechanic to replace it with a clamp/fastener rather than a C clip then hey presto had my power back at low revs.
Maybe book it in to a garage? I'm on my mobile so can't see where you're from?
Are you sure both turbos are okay? What about taking a look at others experiencing the same issues?
Here's one I found;
http://www.e90post.com/forums/showthread.php?t=968480
Reply
e90post
