THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Front reflector
      01-09-2015, 09:52 AM   #1
Bam226
Drives: BMW 228i M sport
Front reflector
Getting my front bumper holes fixed and was seeing if anyone else painted them. Or is getting an aftermarket one as a replacement the best option? Thanks
      01-09-2015, 11:50 PM   #2
NEUE02
NEUE02's Avatar
267
Drives: M235i
I bought some, painted by IND, but they did not match. The metallic in my Melbourne Red was off and they appeared lighter than the surrounding paint. Looked bad and attracted more attention rather than disappearing into the background. Results may be better with solid colors.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S
      01-10-2015, 07:24 AM   #3
Bam226
Ya that's what I was worried about. I'm just going to have a body shot paint them to match.
      01-10-2015, 12:24 PM   #4
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
mine matched exactly
      01-10-2015, 02:23 PM   #5
Bam226
Where did you purchase yours and are they glued or clipped in?
      01-10-2015, 02:50 PM   #6
F80_M
Drives: 1/1 PSM F80, F36, G11
Same with mine. They matched up perfectly. I'm sure if they don't match up perfectly IND will send you another set. Maybe it was just a bad batch?
      01-10-2015, 03:46 PM   #7
pikcachu
pikcachu's Avatar
1403
Ind.. they clip
      01-10-2015, 07:10 PM   #8
NEUE02
NEUE02's Avatar
267
Drives: M235i
I emailed them and this was their reply:
"The reflector will not be 100% match as its a separate part from the bumper. The angle of light will hit it differently showing slight change in color."
Based on this response I had no confidence that another try would work out better.
The Stable
      01-14-2015, 10:53 PM   #9
benes136
Drives: 2014 M235i Estoril Blue
My Estoril Blue ones match perfectly. Looks great!
      01-14-2015, 11:15 PM   #10
pikcachu
pikcachu's Avatar
1403
Mine too
      01-22-2015, 08:36 PM   #11
MrBallooKnot
Drives: Like I Stole It
I just put in my Mineral White ones in tonight. They look a little lighter than the OEM paint in certain lighting. I think their point about them not matching 100% is probably fair for certain colors. I think light colors are tricky and the metallic sprays can probably look different unless the spray angles are identical. Anyway, here's a picture of mine.
2addicts
