Have I got a leg to stand on?
01-11-2015, 11:16 AM | #1 |
Rep 937
Hi guys,
I've noticed the last couple of days I seem to have the early stages of clutch judder. First and second gear, judders. Hot or cold, all other gears fine. October 2009 reg LCI 320D 107k Full BMW history 2 owners Original clutch as far as I know. I'm guessing with the age & mileage BMW won't do anything so I either cough up at an Indiy, or live with it? Thanks Jordan |
01-11-2015, 11:25 AM | #6 |
Rep 9,097
From the memory, one of the forum member bought it from ECP and changed it himself (with his mate).
01-11-2015, 11:32 AM | #7 |
Rep 937
01-11-2015, 11:42 AM | #12 |
Rep 937
01-11-2015, 11:44 AM | #13 |
Rep 166
I've heard off a mate who used to work at bmw it's not a massively hard job as long as have the right tools/ramp but guess could be said about anything, my local Indy said that clutch judder will happen in most 320ds and not a major issue unless it gets a lot worse.
Could still have quite abit of life in it though |
01-11-2015, 11:45 AM | #14 |
Wheelbarrow Edition
60
Rep 1,608
Dual mass flywheel giving up
Clutch is probably fine but if your changing flywheel might as well change clutch at 107k But doesnt need done imminantly |
01-11-2015, 12:00 PM | #15 | |
Rep 842
Warranty bill to BMW was over £1200 iirc, they claimed it was a engine out job |
01-11-2015, 12:54 PM | #16 |
Rep 2,399
If parts are 450, come and take a drive down my side and ill get labour charge for around £150. Gearbox has to come out for most clutch and flywheel change. (Btw, you will change the flywheel wont you if your thinking of changing clutch)
01-11-2015, 01:34 PM | #17 |
Rep 5,623
You could try fitting a clutch delay valve, which gets rid of any delay. Quite a cheap and easy job to try. Can either buy one or mod your existing one.
http://www.zeckhausen.com/cdv.htm |
01-11-2015, 02:02 PM | #18 |
Rep 842
01-11-2015, 02:05 PM | #20 | |
Rep 937
I think il be able to get a similar labour rate from our local mechanic as he's been the family mech for years. Il see how bad it gets first though as there's no plan to change car for quite a while now |
