01-19-2015, 06:37 PM | #1 |
Rep 83
Your US i3 actually has 2.4 Gal fuel tank - Mike Mas
Featured on BIMMERPOST.com Ok you guys are not going to believe this – I’m sure we’re all aware of the lack of fuel tank size in our I3’s with Europe having 2.4 gallons and here in the US we only have 1.9 gallon tanks. Words out from some coding experts that both cars have the same exact tank - BMW has cleverly programmed the US cars to run out of fuel at 1.9 gallons when in fact it has 2.4 gallon capacity and there is still fuel remaining in the tank when the gauge shows “0 miles” on the fuel gauge. It appears this is accomplished by shutting off the fuel pump at 1.9 gallons. A quick coding change addresses the problem and the tank will show full 2.4 gallon capacity and additional mileage. Mike Mas Last edited by LowOnCash; 01-21-2015 at 08:11 AM.. |
01-19-2015, 09:27 PM | #2 |
Rep 2,737
Figured, when I looked up that on realOEM.com they had the same part number for the euro and U.S. spec fuel tanks. Plus it didn't make sense to spend all that money to tool up 2 fuel tanks.
01-20-2015, 11:03 AM | #3 |
Rep 11,785
great article...... and thanks for the full explanation on the beancounters vs the auto manufacturers?
it's great that software guys are finding the " digital screwdriver" in order to bring tuning back to the people. Last edited by M3 Adjuster; 01-20-2015 at 11:13 AM.. |
01-20-2015, 11:09 AM | #5 |
Rep 4,216
interesting... what does BMW REALLY think of us???
2020 F87 M2 Competition /l\ LBB /i\ Executive Package 2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV BMW CCA Member |
01-20-2015, 11:20 AM | #6 | |
Rep 11,785
I went back and read the article that was posted. The OP explained exactly why. It's easy to blame BMW (certainly a bimmerpost pastime!) , but in this case BMW is simply abiding with US GOVT REGULATIONS. |
01-20-2015, 11:24 AM | #9 |
Rep 569
They explained why, and it has nothing to do with what BMW thinks about you.
01-20-2015, 11:27 AM | #10 |
Emperor
22
Rep 189
Thanks for posting this! I am not surprised... now legal, CARB and other issues aside, if we could please have fix for this and the charge hold feature, I will be a little happier with mine....
01-20-2015, 11:27 AM | #11 |
Rep 4,216
Oops! I didn't see the attached image with the explanation on my iDevice. Apologies...
01-20-2015, 11:31 AM | #12 |
Resident Kerbalnaut
478
Rep 10,703
Well this is certainly interesting.
Now if only BMW let me turn on the generator manually, is that another US regulation at play? If im going 120 miles I want to be able to run the jenny at a low setting the entire time, dammit. |
01-20-2015, 11:49 AM | #13 | |
Rep 616
Just a hunch though.
ED 11/3/14 2015 M3, AW, SO, DCT, 19" blk wheels, HK, Lighting/Exec/Tech packages, ad. susp.
01-20-2015, 12:14 PM | #14 |
Rep 646
Argh damn. Same here. Sorry for my quick outburst!
| 2021 Tesla Model 3 |
01-20-2015, 01:05 PM | #17 |
A family of bimmers
2757
Rep 7,743
more than likely a US Gov't regulation since people dont listen to warnings and would continue to drive anyways and then run out of fuel
thats what i got out of this thread too. and here i thought 2.83 was cheap.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
01-20-2015, 01:51 PM | #18 | |
Resident Kerbalnaut
478
Rep 10,703
Its insane. Its literally a third difference. |
01-20-2015, 02:22 PM | #19 |
Rep 4,567
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
01-20-2015, 04:02 PM | #20 | |
REBEL
783
Rep 1,280
01-20-2015, 04:23 PM | #21 |
Rep 1,061
To get the maximum federal credits, the REx augmented distance cannot be larger than the unaided strictly battery range, so to meet CARB regulations, they made the (effective) fuel tank size smaller.
Running a gasoline engine dry is not good for things like pumps or injectors, and the logic to restart it with lots of cranking to get all of the air out puts wear on things, too. And, similar to your house water plumbing, draining the pipes then refilling them can dislodge some crud and create problems even with a good filter. It's best to avoid running one dry. |
01-20-2015, 06:48 PM | #22 | |
Rep 83
