Shorter differential and UUC Transmission Mount review
01-21-2015, 08:38 PM | #1 |
Rep 403
My car : 330I 2006 6MT
My rear differential gear ratio was 3.15 OEM, I put an 3.64, what a difference, car is so much faster. To give you an idea, in 6th speed at 120kh I was at 2500rpm, now Im at almost 3000. They should of put this gear ratio when they sold the car, its night and day. Now the worse, UUC transmission mount (The black one), A reputable shop (Vag Motorsport) Installed them, so the installation was properly done. It vibrated SO MUCH, its crazy, I almost tought my car was broken. I putted back the stock ones tonight, no more vibration. So Be aware if you put these mounts |
01-21-2015, 09:42 PM | #3 |
Rep 403
the blue mounts are replacement for the red one's. If mines (the black ones, for Street use) vibrated that much, yours should be worst
I dont think these are good for a Daily drive |
01-21-2015, 10:47 PM | #5 | |
Rep 3,778
Drives: '11 328i '19 M6
Installation all done by Classic BMW Motorsports race team in Plano, TX and currently at about 7-8K miles on the build without a single issue. The clutch is a dual solid friction disc Clutchmasters 850 stand type design with a billet flywheel and it's still not an issue for vibration even with a solid body mounted CAE Ultra Shifter and AKG Motorsport DSSR. Not sure why you're having so much vibration. Differential is a Performance Gearing LSD geared down to 3.73 from 3.23 to make sixth the 1:1 gear and get rid of the pointless overdrive. Difficult to drive off the line but vastly better than stock through the gears. Agreed that this final ratio, or equivalent, should be standard. [edit] And yes, this is my daily [/edit] [edit again] The increased vibration with just the trans mounts _might_ be due to basically providing a pivot point for the engine on its stock mounts to vibrate worse than it would otherwise. With the rigid engine and trans and diff mounts the engine has to shake a lot more mass so the vibration excursion would be less. Might explain why you found the vibration so much worse than I'd expect. But the solution is probably not acceptable either. Have you considered more rigid engine mounts? [/edit]
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
01-22-2015, 09:03 AM | #6 |
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
Was it just a matter of swapping the rear diff with an AT diff? Was there any other components you needed for the swap? I am really interested in doing this.
01-22-2015, 09:52 AM | #7 |
Rep 9,004
I had UUC mounts (with enforcer cups) in my Z3 - the vibrated like crazy! I had the shop readjust them, which took away most of the vibration, but you would always get this crazy LOUD resonance when I coasted from 5000RPM down.
Go with Rogue Engineering. |
01-22-2015, 10:20 AM | #8 |
Rep 7,215
I ran a solid diff bushing once. I lasted about a week. Unless you're pretty much racing your car wheel to wheel, it's not worth it IMO.
poly subframe and motor mounts seem to be fine. avoid solid diff & transmission mounts unless you really like NVH. FYI, the DME is coded to your diff. I don't know what it will affect specifically but it uses it to detect what gear you are in. 3.15 to 3.64 is enough of a difference that it will think you're in the wrong gear. it would be trivial to change for me but if you're getting a tune you'd want to let them know. |
01-22-2015, 10:55 AM | #9 |
Resident Tamed Racing Driver
298
Rep 4,697
Avoid anything made by UUC. They are easily the worst company for BMW aftermarket parts.
If you are looking for a stiffer trans mount, get the M3 or Rogue Engineering mounts.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
01-22-2015, 11:13 AM | #10 |
Rep 3,778
Not arguing with you guys at all, just somewhat confused why everyone seems to get unacceptable levels of NVH with solid mounts, trans, diff, or otherwise. And the UUC mounts look like new. Admittedly not that many miles but no issues yet. If they go I'll just switch to solid aluminum mounts and be done with it. The engine's going to get blueprinted and balanced and get an ATI damper (if they ever finish it...) so this shouldn't be an issue. Certainly doesn't seem to be one now.
Absolutely not the slightest bit of howling from them at all. Some gear whine when lifting but that's no surprise, it'd be odd if there wasn't any and yes it comes from the transmission. [edit] Maybe it's due to running Red Line MTL but that seems like a real stretch... [/edit] If there's any from the diff it's drowned out by the trans. Still isn't a problem and not audible over the radio really. The exhaust is much louder. BTW, the vibration shows up on the datalogger as a lateral component, no surprise there either. Maybe I'm immune to NVH from driving so many shitty cars for years, dunno. Help me understand what the deal is with NVH, seriously I'm not understanding here at all. Is it because a silent, smooth ride is expected or desired? If so I can't for the life of me reconcile this with track performance and maybe that's the problem in and of itself. Nobody who would want a quiet smooth ride is looking for track-like performance from their daily, is that the deal? Maybe I'm just not into compromise or something. Or completely nutz, that's always a possibility..
01-22-2015, 11:18 AM | #11 | |
Rep 3,778
Thanks very much
01-22-2015, 11:29 AM | #12 |
Rep 3,778
Was it really loud gear whine or something else added to the whine?
01-22-2015, 11:56 AM | #13 | |
298
Rep 4,697
The amusing part is that someone who mods exactly to my own taste, I'm frequently questioned by others as to why I did not elect to be more aggressive in my own car. They instantly assume it must be a track focused car and question the decisions made, despite frequent statements on my part that DDing is far and away its primary function.
01-22-2015, 12:38 PM | #15 | |
Rep 3,778
01-22-2015, 12:39 PM | #16 |
Rep 3,778
May be. Maybe it was coupled well enough to set up a resonance that might not otherwise exist. Might be car dependent, dunno. Sucks either way though.
01-22-2015, 12:40 PM | #17 |
298
Rep 4,697
Pretty much. My brother is in a similar camp to you, where my primary focus is fun, followed by comfort.
01-22-2015, 12:44 PM | #18 |
Rep 403
I took my differential from the same car (A/T 330I), nothing else you need, everything is bolt on. I paid 300$ for the diff and 200$ for the installation (You could DIY Its seems to be pretty easy)
01-22-2015, 12:50 PM | #19 | |
Rep 403
There's no difference except the car seems to be A LOT faster, DTC stil work perfectly also. |
01-22-2015, 12:54 PM | #20 |
Rep 403
BTW With the UUC Transmission mount, I double check yesterday to be sure they were properly installed and not overtorqued, everything was fine.
At first, I tought they were something wrong with my differential or driveshaft, I put the car in neutral (No more differential or driveshaft movement), and I reved the engine and the vibration was there from 2k and up, but CRAZY vibration. I almost suspected something wrong with my engine. Took them off put back OEM one, smooth as butter now |
01-22-2015, 01:36 PM | #21 | |
Rep 3,778
[edit] You literally can't feel but the slightest vibration even at idle even when holding on to the wheel. Above 2K there's nothing but the road. Suspecting that not running the same type of mounts down the entire driveline is a likely source of excessive vibration. [/edit]
01-22-2015, 01:37 PM | #22 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
I tried the black mounts a year ago, no enforcer cups. NVH was more than I expected. Didn't make a stink about it on forum as I thought perhaps I screwed up the DIY. UUC was kind enough to take them back.
I plan to install new Lemforder OEM mounts this weekend as my currents have over 130k on them. I'll post anything unusual but I'm not expecting anything. |
