I just want a decent independent
01-23-2015, 05:26 AM | #1 |
Rep 396
<Sigh>
My car was recently due a simple oil service, and as it's now out of warranty I'm trying to settle on a decent independent for this kind of job. I spotted one on Pistonheads 'recommended garages' Wiki so I thought I'd give them a go. I'd also had a few 'control system failure' messages the previous week, but they had cleared up over the last couple of days. My car is reasonably standard but has a JB4 and BMS dual-cone intake, Alpina gearbox software, CIC upgrade, LCI rear-lights etc. My first inkling that this wasn't going to go well was when the mechanic insisted that my car had the N52 engine when I took it in and he was taking details. No amount of me insisting it was N54 would convince him until he went out to the car and checked the chassis plate. Not a good start. I asked him if I should disable the JB4 and he assured me he could work around it. However, when he called me later in the day he told me he hadn't been able to do anything on the car as his diagnostics kit couldn't communicate. I told him he should have called me and I'd have talked him through disabling it but he was insistent that even with the JB4 disabled, it would still prevent him 'talking to the car. I think that's cobblers. So, he spent a full day trying to diagnose the 'control system' codes I was getting and didn't have chance to do the service, so I left the car with him another day. I turns out that in order to diagnose the car, he had to take the JB4 off. We agreed that he'd carry out the service and I'd collect the car the next day. I turned up yesterday and was presented with a bill for the service, plus two hours diagnostics which was apparently reduced from 4 hours as "good will". I agreed with him that I'd leave the JB4 off for a couple of weeks and see how the car ran, but made it clear that I wasn't happy that he hadn't rang me when he had problems diagnosing. Again, he insisted that even disabling the JB4 would prevent him from using his kit. Anyway, the icing on the cake ... I drive the 20 miles home last night, reverse onto the drive, and receive an "oil level low - add a litre of oil" warning light. The warning is present this morning too. I'm assuming my oil level sensor is either broken, or they've drained the oil and not put any more in, or left a cap off or something. FFS. This is mostly a rant, but hopefully y'all can answer these questions: 1 - with the JB4 disabled, ie on map 0, should diagnostics equipment be able to communicate with the car? 2 - any way to check the oil level on the N54? I've opened the cap on top of the engine but obviously all I can see is oily bits. Cheers Frustrated of Manchester |
01-23-2015, 05:36 AM | #2 |
Rep 505
1. Yes
2. You can view the service and oil level via the sat nav screen I recently had mine serviced and a general check by A1BN Specialist BMW and they no issues running diagnostics once I'd disabled the JB4. |
01-23-2015, 05:45 AM | #3 |
Rep 286
im from near you out of curiosity which independent did u use?
in the past i have used bm tech they were a bit pricey when i had my e46 few years back but always got job done. now i always use baymow these guys are excellent and know what their on about customer service is top and they are very straightforward. darren woods is also a highly recommended indy but ive not used them yet personally. |
01-23-2015, 06:40 AM | #5 |
Rep 3,312
The JB4 disabled will allow diagnostics etc to be run as when active it disables the OBD port.
Unsure how you'd check apart from the iDrive screen. Yup totally in agreement with you here. I cannot trust the iDrive level screen as you just can't be 100% sure it's actually working properly.
01-23-2015, 07:01 AM | #6 |
Rep 4,021
Sound like a fine garage. Not!
Good garages are few and far between. The other issue is their knowledge simply can't be wide enough to cover all cars and their issues. Not knowing what they are doing and then passing the cost back to you is pretty low though. I hate the lack of dipstick too. I just hope the oil isn't too low and has caused damage. |
01-23-2015, 07:03 AM | #7 |
Rep 9,097
1- yes
2- check via idrive after driving few miles, hence bmw insist that their technician should go out for test drive. Its everywhere mate. I have take my f10 to a well reputed garage recently for lowering springs and experience / communication is absolutely appalling.
01-23-2015, 07:07 AM | #8 |
Rep 2,796
Yep I've still to master the JB4but once this is disabled easy as as you discovered Manish
01-23-2015, 07:08 AM | #9 |
Rep 2,796
OP Darren Wood..... Got a very good reputation from what I can gather and he's in your neck of the woods
01-23-2015, 07:13 AM | #11 | |
Rep 2,796
01-23-2015, 08:42 AM | #13 | |
Rep 396
Thanks all for confirming that disabling the JB4 would allow diagnostics to work. That just confirms that had he called me first I could have talked him through it and saved us both some bother. In the 3 years I've owned the car, the iDrive has never reported anything but maximum oil. Now it's reporting empty. It just seems a little odd that it's now doing this after it's had an oil service. I've also just noticed a screw missing from the cowling around the top of the engine bay. I've heard of Darren Wood and I know they have an excellent reputation, they're just a bit of a trek away from me. Small price to pay, in hindsight. I'm going to ring BM Tech in a moment. |
01-23-2015, 09:20 AM | #14 |
Rep 902
A second recommendation for Darren Wood (based in bredbury, stockport) very good rep, a a genuinely nice bunch of guys.
I have my car taken care of by them for everything, very good pricing too and it's on their website |
01-23-2015, 09:42 AM | #15 | |
Rep 2,343
This sounds like a handy plus as I seem to recall cars being stolen with use of the OBD port. Provided thieves don't know about JB4 controls. |
01-23-2015, 10:08 AM | #16 |
Rep 396
Ok, I've just spoken to the garage and apparently it's very difficult to get the oil level right on the N54 and I've been advised to add 1l and see if it resolves.
01-23-2015, 10:16 AM | #17 |
Rep 3,200
Drives: E92 325i MSport Coupe
That really takes the biscuit! What a load of BS. You fully drain the engine and filter and re-fill with the correct required quantity. What's difficult about that?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
01-23-2015, 10:19 AM | #18 |
Rep 396
I've no idea. He said the procedure is to add 5l, take it for a run, and if it asks for more then add another litre. It sounded like bollocks to me, too.
01-23-2015, 11:01 AM | #19 | |
Rep 2,337
Also it only blocks OBD when DME is active, so it wont protect you from thieves. (If DME is active then they already have ignition) |
01-23-2015, 12:38 PM | #21 |
Rep 38
Oil
Hello mate, touch too late but just to add my bit and possibly give a very slight piece of (amateur) reassurance: I have experienced the same faults regarding oil level reading in the past. It happened to me on my 330i, 630i and THIS WEEK on my 325i e93. On all occasions I knew the oil level should be okay and for safety took the car into a trusted Indy just to ensure there was nothing sinister going on-hidden leaks etc. Each time half a litre of oil was added so as not to overfill and this cured the problem and corrected the reading.
I also concur with others comments, not fitting a dipstick is nonsense and technology will never provide the reliability that a single piece of metal will. Hope your problem is now resolved and you can drive the car without concern |
01-23-2015, 02:17 PM | #22 |
Rep 145
I noticed you are located in the North West, if you're not too far from Preston I use a great independent specialist. Ex Bowker lads and proper enthusiasts with a passion for bikes.
