01-26-2015, 09:09 PM | #1 |
Rep 126
Considering getting the following parts for my F30 328i xDrive
http://www.rwcarbon.com/bmw-f30-320i...k-spoiler.html
http://www.rwcarbon.com/bmw-f30-f31-...r-grilles.html http://www.rwcarbon.com/bmw-f30-f31-...fiber-lip.html http://www.rwcarbon.com/41/11/0/590/...or-covers.html Anyone have any experience with these parts? I've never done any modifications before to a car so I'm pretty new to this. The Mirror covers and the rear lip spoiler look pretty straight forward to install, but the front grill and lip look complicated. |
01-27-2015, 10:45 AM | #2 | |
Rep 826
Drives: G80 M3 & G87 M2
Trunk Spoiler: Uses 3M double sided tape. Apply a generous amount to the bottom and to the edges and press and hold into place. An extra pair of hands is very helpful to line everything up. Mirror Covers: The OEM ones unscrew and pop right off. Ours use tabs and just pop right into place. Grilles: You will need to access the back of the grilles and press down the tabs in the back to release them. It is best that you heat up the tabs with a heat gun or in the sun to make sure they do not crack. The new grilles pop right into place using the same mounting locations. Front Lip: This will use a little bit of 3M double sided tape and the use of self taping screws. This is also a great job to have someone help you line up the lip and hold it into place as you screw it on. If you are hesitant to installing any part, any reputable body shop will have no problem installing these items. Everything is in stock right now. If you have any further questions feel free to PM me or give me a call
Carbon fiber for the everyday driver: rwcarbon.com 3941 E La Palma Ave Anaheim CA, 92870 info@rwcarbon.com / (714) 328-4406 Instagram/Tiktok/Facebook: @rwcarbon |
