01-27-2015, 06:55 PM | #1 |
Rep 240
Got my BMS stage 1 confused about install
Hey guys, im a complete newb when it comes to engine installs. I got my BMS stage 1 and I looked through the install guides and even multiple videos, but after I popped my cover off and looked into my engine bay everything got confusing. I have a f30 335i harness B according to burger tunings website. I pop the cover off and look at the right side of the engine (when im facing it). There is this plug there that I believe is the TMAP its right next to this silver metal thing. Is this the tmap or is there another one im not seeing? Also the second connector which is on top of the engine hidden behind rubber. I pulled up the rubber and could not find that connection there.
Pretty much is there a easy way to know exactly what im supposed to unplug and connect to the BMS? Am I just being too cautious?
2013 BMW 335I M-Sport: Premium, Cold Weather, Drivers Assist, Tech, HK, Sports Auto
01-27-2015, 07:48 PM | #2 | |
@obriennathaniel_f30 on Instagram
515
Rep 1,062
Drives: 582whp/596wtq '13 335i
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
01-27-2015, 08:44 PM | #3 |
Rep 240
So i cant possibly plug this into the wrong place?
01-27-2015, 08:58 PM | #4 |
515
Rep 1,062
pretty much lol. unless you force a connector, even then i still dont think you could.
01-28-2015, 02:48 AM | #5 |
Rep 240
Perfect makes me feel better lol. Ill just give it a shot tomorrow.
01-29-2015, 09:55 AM | #6 |
Rep 851
Theres 2 youtube vids that show you the two plugs.. just watch them 10x with your engine bay open. You'll get it. The hardest part is removing the plugs at first because you have to press down really hard on the little fuckers to disengage the clip then pull. Use one hand to press down on the little clip all the way down first and use your other hand to pull. It should come off relatively easy once the clip is disengaged, if your pulling hard and its not budging then the clip is still engaged and your not pressing down hard enough.
01-29-2015, 12:41 PM | #7 |
Rep 240
I finally got it installed it took about 30 minutes to figure out those stupid clips, I still dont know how I got them off.
I have a couple of questions about the BMS stage 1. First question is i routed my box to the left side of the engine bay and put it where the battery charging thing is. Will this be an issue? Ill post a picture of it right now. Second question sometimes I feel like theres a huge power increase and sometimes i feel like nothings changed. What the hell is going on? It just feels like a weird place to put it.
01-29-2015, 12:53 PM | #8 | |
BimmerPost Supporting Vendor
4927
Rep 116,037
Mike |
01-29-2015, 01:42 PM | #9 |
Rep 240
Yeh I think i got the hang of it hopefully for the next time. Thanks for the routing info.. I needa fix that.
01-29-2015, 11:51 PM | #10 | |
Rep 444
01-30-2015, 12:41 AM | #11 |
Rep 240
Hopefully in a few days itll be good, because when the power is there it feels great.
01-30-2015, 10:46 AM | #13 |
515
Rep 1,062
01-31-2015, 04:05 AM | #14 |
Rep 240
Lolll yeah ive been meaning to clean it .
01-31-2015, 02:25 PM | #15 |
13128
Rep 18,795
@AHB900, let me know if you still need help.
Come by when you have spare time, and I'll help you. No charge.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-01-2015, 03:22 AM | #16 |
Rep 240
Hey R33 i actually got it installed finally. Thanks though.
02-01-2015, 09:28 AM | #17 |
13128
Rep 18,795
Good..
